99-1430-812-04
99-1430-812-04
    BINDER(宾德)
99-1430-812-04 数据手册
Product data sheet Automation technology - sensors and actuators Product description M12-A female cable connector, Contacts: 4, 6.0 - 8.0 mm, shieldable, screw clamp, IP67, UL Area Order number M12-A series 713 99 1430 812 04 Illustration Scale drawing Contact arrangement You can find the component part drawing and assembly instructions on the next page. Technical data General values Connector design Connector locking system Termination Wire gauge (mm) Wire gauge (AWG) Cable outlet Upper limit temperature Lower limit temperature Customs tariff number Packaging Unit Electrical values female cable connector screw screw clamp 0.75 mm² 18 6.0 - 8.0 mm 85 °C – 40 °C 85369010 50 Cable data Approval 1 Rated current (40 °C) Rated voltage Rated impulse voltage Pollution degree Overvoltage category Insulating material group Insulation resistance EMC compliance Degree of protection Mechanical operation 4 A (3 A UL) 250 V 2500 V 3 II III > 10⁸ Ω shieldable IP67 > 100 Mating cycles Material UL Contact material Contact plating Contact body material Housing material CuZn (brass) Au (gold) PA Zinc die-cast nickel-plated Date: 2020-01-19 - Page 1 of 3 Product data sheet Automation technology - sensors and actuators Product description M12-A female cable connector, Contacts: 4, 6.0 - 8.0 mm, shieldable, screw clamp, IP67, UL Area Order number M12-A series 713 99 1430 812 04 Component part drawing Assembly instructions / Panel cut-out Date: 2020-01-19 - Page 2 of 3 Powered by TCPDF (www.tcpdf.org) Product data sheet Automation technology - sensors and actuators Product description M12-A female cable connector, Contacts: 4, 6.0 - 8.0 mm, shieldable, screw clamp, IP67, UL Area Order number M12-A series 713 99 1430 812 04 Security notices The connector must not be connected or separated under load. Non-observance and incorrect use can result in personal injury. The connectors are designed for use in plant, control system and electrical equipment. The end user is responsible for checking whether the connectors are suitable for use in other applications. To prevent the connector being opened unintentionally when used in electrical circuits containing hazardous life parts, the thread between the housing and the connector head must be secured using a suitable cyanoacrylate adhesive. This does not apply to connectors used in SELV and PELV circuits according to IEC 61140 (EN 61140, VDE 0140-1). Connectors used in electrical circuits containing hazardous life parts must only be assembled and used by or under the supervision of persons with the requisite electrotechnical training, taking the applicable regulations and standards into account. Connectors with degree of protection IP 67 and IP 68 are not suitable for use under water. When used outdoors, the connectors must be separately protected against corrosion. For further information about IP degrees of protection refer to ‘Technical support’ in the Download Centre. To lock the cable connector to the equipment connector, the threaded ring is tightened until it is ‘finger-tight’ (approx. 50 cNm). Date: 2020-01-19 - Page 3 of 3
99-1430-812-04
物料型号:M12-A系列 713,订单号99 1430 812 04。
器件简介:这是一个M12-A型的女性电缆连接器,适用于自动化技术领域中的传感器和执行器。
引脚分配:具有4个接触点,电缆直径在6.0 - 8.0 mm之间。
参数特性: - 额定电流(40°C):4A(美国保险商实验室标准3A) - 额定电压:250V - 额定脉冲电压:2500V - 污染等级:3 - 过电压类别:II - 绝缘材料组:III - 绝缘电阻:大于10⁸欧姆 - EMC合规性:可屏蔽 - 保护等级:IP67
功能详解:连接器设计为女性电缆连接器,采用螺丝锁定系统和螺丝夹紧端子。适用于0.75 mm²(18 AWG)的线规。连接器设计用于在工厂、控制系统和电气设备中使用,并有安全提示以确保正确使用。
应用信息:连接器适用于自动化技术领域,需要在各种环境条件下稳定工作。
封装信息:接触材料为铜锌合金(黄铜),镀金接触点,接触体材料为PA(尼龙),外壳材料为镀镍锌合金压铸。
99-1430-812-04 价格&库存
很抱歉,暂时无法提供与“99-1430-812-04”相匹配的价格&库存,您可以联系我们找货
