Product data sheet
Miniature connectors
Product description
M16 IP67 female cable connector, Contacts: 8 DIN, 6.0 - 8.0 mm, shieldable, solder, IP68, UL, AISG compliant
Area
Order number
M16 IP67 series 423
99 5672 15 08
Illustration
Scale drawing
Contact arrangement
You can find the component part drawing and assembly instructions on the next page.
Technical data
General values
Connector design
Connector locking system
Termination
Wire gauge (mm)
Wire gauge (AWG)
Cable outlet
Upper limit temperature
Lower limit temperature
Customs tariff number
Electrical values
screw
solder
0.75 mm²
18
6.0 - 8.0 mm
95 °C
– 30 °C
85369010
Degree of protection 2
Mechanical operation
Cable data
Approval 1
Approval 2
Rated current (40 °C)
Rated voltage
Rated impulse voltage
Pollution degree
Overvoltage category
Insulating material group
Insulation resistance
EMC compliance
UL
AISG compliant
5A
60 V
500 V
1
I
III
≥ 10¹⁰ Ω
shieldable
IP68
IP67
IP67
> 500 Mating cycles
Material
Contact material
Contact plating
Contact body material
CuSn (bronze)
Ag (silver)
PBT (UL 94 V-0)
Date: 2019-09-22 - Page 1 of 3
Product data sheet
Product description
Area
Order number
M16 IP67 series 423
99 5672 15 08
Component part drawing
Assembly instructions / Panel cut-out
Date: 2019-09-22 - Page 2 of 3
Powered by TCPDF (www.tcpdf.org)
Product data sheet
Product description
Area
Order number
M16 IP67 series 423
99 5672 15 08
Security notices
The connectors are designed for use in plant, control system and electrical equipment. The end user is responsible
for checking whether the connectors are suitable for use in other applications.
Connectors with degree of protection IP 67 and IP 68 are not suitable for use under water. When used outdoors, the
connectors must be separately protected against corrosion. For further information about IP degrees of protection
refer to ‘Technical support’ in the Download Centre.
To lock the cable connector to the equipment connector, the threaded ring is tightened until it is ‘finger-tight’
(approx. 50 cNm).
Date: 2019-09-22 - Page 3 of 3
很抱歉,暂时无法提供与“99-5672-15-08”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+276.14372
- 5+227.27158
