99-9135-50-12
99-9135-50-12
    BINDER(宾德)
99-9135-50-12 数据手册
Product sheet miniature Product Contacts: 12, male panel mount connector, red Area Article number Snap-in IP67 Series 720 99 9135 50 12 Illustration Scale drawing Contact Arrangement You can find the item description and assembly instruction on the next page. Technical data Common values Connector Design Connector locking system Termination Wire gauge (mm) Wire gauge (AWG) Cable outlet Upper temperature Lower temperature Electrical values male panel mount connector snap solder 0,25 mm² 24 85 °C -25 °C Rated voltage Rated impulse voltage Pollution degree Overvoltage category Material group Rated current (40°C) Volume resistivity EMV compliance Degree of protection 60 800 V 2 II II 2A ≤ 3 mΩ not shielded IP67 Material Material of contact Contact plating Material of contact body CuZn (Messing) Au (gold) PA (UL 94 V-0) Date: 2016-04-08 - Page 1 of 2 Powered by TCPDF (www.tcpdf.org) Product sheet miniature Product Contacts: 12, male panel mount connector, red Area Article number Snap-in IP67 Series 720 99 9135 50 12 Item description Installation instructions / Mounting cutout Date: 2016-04-08 - Page 2 of 2
99-9135-50-12 价格&库存
很抱歉,暂时无法提供与“99-9135-50-12”相匹配的价格&库存,您可以联系我们找货
  • 1+143.70054
  • 10+139.63915
  • 50+135.05706
  • 100+132.12035
  • 250+129.87097
库存:3
