Product data sheet
Connectors for medical applications
Product description
Contacts: 5, male panel mount connector
Area
Order number
Snap-in IP67, subminiature Series 620 MED
99 9215 400 05
Illustration
Scale drawing
Contact arrangement
You can find the component part drawing and assembly instructions on the next page.
Technical data
General values
Connector design
Connector locking system
Termination
Wire gauge (mm)
Wire gauge (AWG)
Upper limit temperature
Lower limit temperature
Electrical values
snap
solder
0,25 mm²
24
85 °C
-25 °C
Rated current (40 °C)
Rated voltage
Rated impulse voltage
Pollution degree
Overvoltage category
Insulating material group
Volume resistivity
Insulation resistance
EMC compliance
Degree of protection
2A
63 V
800 V
2
II
II
≤ 3 mΩ
≥ 10¹⁰Ω
Shielding is not possible
IP67
Material
Contact material
Contact plating
Contact body material
Housing material
CuZn (brass)
Au (gold)
PA (UL 94 V-0)
PA
Date: 2018-11-22 - Page 1 of 3
Product data sheet
Product description
Area
Order number
99 9215 400 05
Component part drawing
Assembly instructions / Panel cut-out
Date: 2018-11-22 - Page 2 of 3
Powered by TCPDF (www.tcpdf.org)
Product data sheet
Product description
Area
Order number
99 9215 400 05
Security notices
The connectors are designed for use in plant, control system and electrical equipment. The end user is responsible
for checking whether the connectors are suitable for use in other applications.
Connectors with degree of protection IP 67 and IP 68 are not suitable for use under water. When used outdoors, the
connectors must be separately protected against corrosion. For further information about IP degrees of protection
refer to ‘Technical support’ in the Download Centre.
Date: 2018-11-22 - Page 3 of 3
很抱歉,暂时无法提供与“99-9215-400-05”相匹配的价格&库存,您可以联系我们找货
