09 0340 00 16
09 0340 00 16
    BINDER(宾德)
    BINDER - 09 0340 00 16 - Circular Connector, 680 Series, Panel Mount Receptacle, 16 Contacts, Solder...
09 0340 00 16 数据手册
Product data sheet Miniature Product description Contacts: 16, female panel mount connector, solder, 12 - 19 contacts, gold plated contacts Area Order number M16 IP40 Series 581/ 680/ 682 09 0340 00 16 Illustration Scale drawing Contact arrangement You can find the assembly instructions on the next page. Technical data General values Connector design Connector locking system Termination Wire gauge (mm) Wire gauge (AWG) Upper limit temperature Lower limit temperature Electrical values female panel mount connector bolted solder 0,25 mm² 24 85 °C -40 °C Rated voltage Rated impulse voltage Pollution degree Overvoltage category Insulating material group Rated current (40 °C) Volume resistivity EMC compliance Degree of protection Mechanical operation 60 V 500 V 1 I III 3A ≤ 3 mΩ Shielding is not possible IP40 > 500 Mating cycles Material Contact material Contact plating Contact body material CuSn (bronze) Au (gold) PBT (UL 94 V-0) Date: 2018-02-05 - Page 1 of 3 Product data sheet Miniature Product description Contacts: 16, female panel mount connector, solder, 12 - 19 contacts, gold plated contacts Area Order number M16 IP40 Series 581/ 680/ 682 09 0340 00 16 Assembly instructions / Panel cut-out Date: 2018-02-05 - Page 2 of 3 Powered by TCPDF (www.tcpdf.org) Product data sheet Miniature Product description Contacts: 16, female panel mount connector, solder, 12 - 19 contacts, gold plated contacts Area Order number M16 IP40 Series 581/ 680/ 682 09 0340 00 16 Sicherheitshinweise The connectors are designed for use in plant, control system and electrical equipment. The end user is responsible for checking whether the connectors are suitable for use in other applications. Date: 2018-02-05 - Page 3 of 3
09 0340 00 16 价格&库存
很抱歉,暂时无法提供与“09 0340 00 16”相匹配的价格&库存,您可以联系我们找货
