09-6503-000-08
09-6503-000-08
    BINDER(宾德)
    BINDER - 09-6503-000-08 - Circular Connector, 26-14AWG, HEC 696 Series, Flange Mount Plug, 8 Contact...
09-6503-000-08 数据手册
Product data sheet Power Product description Contacts: 8(4 + 3+PE), male panel mount connector, rated voltage: 60 V Signal, 400 V Power Area Order number Bajonett HEC Power Series 696 09 6503 000 08 Illustration Scale drawing Contact arrangement You can find the component part drawing and assembly instructions on the next page. Technical data General values Connector design Connector locking system Termination Wire gauge (mm) Wire gauge (AWG) Upper limit temperature Lower limit temperature Electrical values male panel mount connector Bayonet crimp (Crimp contacts must be ordered separately) siehe Crimpkontakte unter Zubehör 100 °C -40 °C Rated voltage Rated impulse voltage Pollution degree Overvoltage category Insulating material group Rated current (40 °C) Volume resistivity EMC compliance Degree of protection Mechanical operation 60 V Signal, 400 V Power V 1000 V 3 III I 3 A Signal, 25 A Power (USR 20 A, CNR 16 A) ≤ 5 mΩ Shielding is not possible IP68, IP69K > 1000 Mating cycles Material Contact material Contact body material depending on crimp contact (accessory) PA Date: 2018-02-05 - Page 1 of 4 Product data sheet Power Product description Contacts: 8(4 + 3+PE), male panel mount connector, rated voltage: 60 V Signal, 400 V Power Area Order number Bajonett HEC Power Series 696 09 6503 000 08 Component part drawing Assembly instructions / Panel cut-out Date: 2018-02-05 - Page 2 of 4 Product data sheet Power Product description Contacts: 8(4 + 3+PE), male panel mount connector, rated voltage: 60 V Signal, 400 V Power Area Order number Bajonett HEC Power Series 696 09 6503 000 08 Assembly instructions / Panel cut-out Date: 2018-02-05 - Page 3 of 4 Powered by TCPDF (www.tcpdf.org) Product data sheet Power Product description Contacts: 8(4 + 3+PE), male panel mount connector, rated voltage: 60 V Signal, 400 V Power Area Order number Bajonett HEC Power Series 696 09 6503 000 08 Sicherheitshinweise The connector must not be connected or separated under load. Non-observance and incorrect use can result in personal injury. The connectors are designed for use in plant, control system and electrical equipment. The end user is responsible for checking whether the connectors are suitable for use in other applications. Date: 2018-02-05 - Page 4 of 4
09-6503-000-08
物料型号:Bajonett HEC Power Series 696 09 6503 000 08
器件简介: - 这是一个8针(4+3+PE)的公头面板安装连接器。 - 额定电压为60V信号,400V电源。
引脚分配: - 引脚2、3、4、5、6、7的分配如下: - 引脚2:0V,-6.60mm - 引脚3:3.68mm,5.50mm - 引脚4:-7.25mm,0.20mm - 引脚5:-5.90mm,-4.20mm - 引脚6:5.90mm,-4.20mm - 引脚7:7.25mm,0.20mm - PE引脚:0V,0mm
参数特性: - 连接器设计:Bayonet(卡扣式) - 连接器锁定系统:卡扣 - 端接方式:线缆压接(压接端子需单独订购) - 线规(mm):0.2mm²至1.5mm² - 线规(AWG):26AWG至14AWG - 上限温度:100°C - 下限温度:-40°C
功能详解: - 电气特性: - 额定电压:信号60V,电源400V - 额定脉冲电压:1000V - 污染等级:3 - 过电压类别:III - 绝缘材料组:未提供具体信息 - 额定电流(40°C):信号3A,电源25A(USR 20A,CNR 16A) - 体积电阻率:≤5mΩ - EMC合规性:未提供具体信息 - 防护等级:IP68,IP69K
应用信息: - 连接器必须在无负载状态下连接或断开。不遵守和错误使用可能导致人身伤害。 - 连接器设计用于工厂、控制系统和电气设备。最终用户负责检查连接器是否适用于其他应用。
封装信息: - 组件部分图纸和组装说明在下一页。
09-6503-000-08 价格&库存
很抱歉,暂时无法提供与“09-6503-000-08”相匹配的价格&库存,您可以联系我们找货
    • 1+89.16328
    • 10+81.99856
    • 25+74.04239
    库存:50
    09-6503-000-08
    • 1+136.41191
    • 10+131.72523
    • 25+114.14130
    • 100+109.50209
    • 250+106.84433
    • 500+104.80355
    库存:17
