76-4331-0011-00008-0200
    BINDER(宾德)
    BINDER - 76-4331-0011-00008-0200 - Sensor Cable, M12 Plug, Free End, 8 Positions, 200 mm, 7.9 ", 713...
76-4331-0011-00008-0200 数据手册
Product data sheet Automation technology - sensors and actuators Product description   Area Order number Illustration M12-A male panel mount connector, Contacts: 8, unshielded, single wires, IP67, UL, M16x1.5 plastic   M12-A series 763 76 4331 0011 00008-0200 Scale drawing Contact arrangement (Plug-in side) You can find the assembly instructions on the next page. Technical data General features Order number 76 4331 0011 00008-0200 Connector design male panel mount connector Wire length 0,2 m Version connector male straight Connector locking system screw Termination single wires Degree of protection IP67 Cross-sectional area 0.25 mm² / AWG 24 Temperature range from/to -40 °C / 85 °C Mechanical operation > 100 Mating cycles Weight (g) 10.023 Customs tariff number 85369010 Electrical parameters Rated voltage 30 V Rated impulse voltage 800 V Rated current (40 °C) 2 A (UL 1.5 A) Insulation resistance > 10⁸ Ω Pollution degree 3 Overvoltage category II Insulating material group III Date: 20.06.2021 Product data sheet Automation technology - sensors and actuators Product description   Area Order number M12-A male panel mount connector, Contacts: 8, unshielded, single wires, IP67, UL, M16x1.5 plastic   M12-A series 763 76 4331 0011 00008-0200 EMC compliance unshielded Material Housing material PA Contact body material PA black Contact material CuZn (brass) Contact plating Au (gold) REACH SVHC CAS 7439-92-1 (Lead) SCIP number 1a3ee487-b7aa-4a8d-829c-3f551a16f801 Authorization/approvals Approvals UL Classifications eCl@ss 11.1 27-44-01-03 ETIM 7.0 EC003570 Date: 20.06.2021 Product data sheet Automation technology - sensors and actuators Product description   Area Order number M12-A male panel mount connector, Contacts: 8, unshielded, single wires, IP67, UL, M16x1.5 plastic   M12-A series 763 76 4331 0011 00008-0200 Assembly instructions / Panel cut-out Date: 20.06.2021 Product data sheet Automation technology - sensors and actuators Product description   Area Order number M12-A male panel mount connector, Contacts: 8, unshielded, single wires, IP67, UL, M16x1.5 plastic   M12-A series 763 76 4331 0011 00008-0200 Security notices The connectors have been developed for applications in plant engineering, control and electrical equipment construction. The user is responsible for checking whether the connectors can also be used in other areas of application. Plug connectors with enclosure protection IP 67 and IP 68 are not suitable for use under water. When used outdoors, the plug connectors must be protected separately against corrosion. For further information on the IP protection classes, please refer to the "Technical Information" download centre. Date: 20.06.2021
76-4331-0011-00008-0200 价格&库存
很抱歉,暂时无法提供与“76-4331-0011-00008-0200”相匹配的价格&库存,您可以联系我们找货
