Product sheet
Miniature connectors
Female cable connector, cable outlet 3-6 mm
M16 connectors IP 40
illustration
Pole
Article number
serie 680
scale drawing
Date: 2013-10-02 - Page 1 of 2
Product
Area
6 DIN
09 0322 00 06
Contact Arrangement
You can find the item description on the next page.
Technical data
Common values
Material
Connector Design
Connector locking system
Screw-locking
Termination
solder
Wire gauge (mm)
0,75 mm²
Wire gauge (AWG)
Max. Cable outlet
3 - 6 mm
Upper temperature
+85 °C
Lower temperature
-40 °C
Material of contact
CuSn (bronce)
Contact plating
Ag (silver)
Material of contact body
PBT (UL 94 V-0)
Material of housing
PA (UL 94 HB)
Cable data
Contacts 6 DIN, female cable connector, cable
outlet 3 – 6 mm, silver plated contacts
Electrical values
Rated voltage
250 V
Rated impulse voltage
1500 V
Pollution degree
1
Overvoltage category
I
Material group
III
Rated current (40°C)
5A
Volume resistivity
≤ 5 mΩ
EMV compliance
not shielded
Degree of protection
IP 40
Mechanical operation
>500 mating cycles
Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de
09 0322 00 06
Product sheet
serie 680
Pole
Article number
Date: 2013-10-02 - Page 2 of 2
Product
Area
6 DIN
09 0322 00 06
Item description
Powered by TCPDF (www.tcpdf.org)
09 0322 00 06
很抱歉,暂时无法提供与“09 0322 00 06”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+97.258611+12.63340
- 5+87.515355+11.36780
- 20+77.7720920+10.10220
- 100+68.02884100+8.83660
