7934065503
7934065503
    BINDER(宾德)
    BINDER - 7934065503 - Circular Connector, 718 Series, Cable Mount Receptacle, 3 Contacts, Solder Soc...
7934065503 数据手册
Product sheet Automation technology Product Area Female cable connector moulded, screw version, M8 x 1 M8 connectors serie 718 illustration Pole Article number scale drawing 3 79 3406 55 03 Contact Arrangement Technical data Common values Material Connector Design Female cable connector Connector locking system Screw-locking Termination crimp, overmoulded on cable Wire gauge (mm) 0,25 mm² Wire gauge (AWG) 24 Upper temperature +85 °C Lower temperature -25 °C Electrical values Rated voltage 60 V Rated impulse voltage 800 V Pollution degree 3 Overvoltage category II Material group II Rated current (40°C) 4A Volume resistivity ≤ 3 mΩ Degree of protection IP 67 Mechanical operation >100 mating cycles Material of contact CuZn (brass) Contact plating Au (gold) Material of contact body PUR Material of housing PUR Cable data material housing PUR insulation single lead PVC single lead structure 32 x 0,1 cable sheath Ø 4.5 conductor resistance 72Ω/Km Contacts 3: cable: 5 m, 3 x 0,25 PUR, Female cable connector moulded, screw version, M8 x 1 79 3406 55 03 Powered by TCPDF (www.tcpdf.org)
7934065503 价格&库存
很抱歉,暂时无法提供与“7934065503”相匹配的价格&库存,您可以联系我们找货
