86-0131-0002-00004
86-0131-0002-00004
    BINDER(宾德)
    BINDER - 86-0131-0002-00004 - Sensor Connector, 713/763 Series, M12, Male, 4 Positions, Solder Pin, ...
86-0131-0002-00004 数据手册
Product data sheet Automation technology - sensors and actuators Product description   Area Order number Illustration M12-A male panel mount connector, Contacts: 4, unshielded, solder, IP68, UL, PG9   M12-A series 763 86 0131 0002 00004 Scale drawing Contact arrangement (Plug-in side) You can find the assembly instructions on the next page. Technical data General features Order number 86 0131 0002 00004 Alternative order number: 09 3431 77 04 Notice Please note that, due to the change from the old to the new order number, there may be deviations in the technical specifications. For questions about product details, please use the ‘Contact Customer Service’ form on the right. Connector design male panel mount connector Version connector male straight Connector locking system screw Termination solder Degree of protection IP68 Cross-sectional area 0.34 mm² / AWG 22 Temperature range from/to -40 °C / 85 °C Mechanical operation > 100 Mating cycles Customs tariff number 85369010 Electrical parameters Rated voltage 250 V Date: 12.07.2021 Product data sheet Automation technology - sensors and actuators Product description   Area Order number M12-A male panel mount connector, Contacts: 4, unshielded, solder, IP68, UL, PG9   M12-A series 763 86 0131 0002 00004 Rated impulse voltage 2500 V Rated current (40 °C) 4 A (3 A UL) Insulation resistance > 10⁸ Ω Pollution degree 3 Overvoltage category II Insulating material group II EMC compliance unshielded Material Housing material Zinc die-cast nickel-plated Contact body material PA black Contact material CuZn (brass) Contact plating Au (gold) REACH SVHC CAS 7439-92-1 (Lead) SCIP number 20d994c4-c38f-4143-b30d-ef499d678f4b Authorization/approvals Approvals UL Date: 12.07.2021 Product data sheet Automation technology - sensors and actuators Product description   Area Order number M12-A male panel mount connector, Contacts: 4, unshielded, solder, IP68, UL, PG9   M12-A series 763 86 0131 0002 00004 Assembly instructions / Panel cut-out Date: 12.07.2021 Product data sheet Automation technology - sensors and actuators Product description   Area Order number M12-A male panel mount connector, Contacts: 4, unshielded, solder, IP68, UL, PG9   M12-A series 763 86 0131 0002 00004 Security notices The connector must not be plugged or unplugged under load. Non-observance and improper use can result in personal injury. The connectors have been developed for applications in plant engineering, control and electrical equipment construction. The user is responsible for checking whether the connectors can also be used in other areas of application. Plug connectors with enclosure protection IP 67 and IP 68 are not suitable for use under water. When used outdoors, the plug connectors must be protected separately against corrosion. For further information on the IP protection classes, please refer to the "Technical Information" download centre. Date: 12.07.2021
86-0131-0002-00004 价格&库存
很抱歉,暂时无法提供与“86-0131-0002-00004”相匹配的价格&库存,您可以联系我们找货
