99-0618-00-06
99-0618-00-06
    BINDER(宾德)
99-0618-00-06 数据手册
Product data sheet Miniature connectors Product description   Area Order number Illustration Bayonet female cable connector, Contacts: 6 DIN, 3.0 - 6.0 mm, unshielded, solder, IP40   Bayonet series 678 99 0618 00 06 Scale drawing Contact arrangement (Plug-in side) You can find the component part drawing on the next page. Technical data General features Order number 99 0618 00 06 Connector design female cable connector Version connector female straight Connector locking system Bayonet Termination solder Degree of protection IP40 Cross-sectional area max. 0.75 mm² / max. AWG 18 Cable outlet 3.0 - 6.0 mm Temperature range from/to -40 °C / 85 °C Mechanical operation > 500 Mating cycles Weight (g) 9.798 Customs tariff number 85369010 Electrical parameters Rated voltage 250 V Rated impulse voltage 1500 V Rated current (40 °C) 6A Insulation resistance ≥ 10¹⁰ Ω Pollution degree 1 Overvoltage category I Insulating material group III EMC compliance unshielded Date: 11.07.2021 Product data sheet Miniature connectors Product description   Area Order number Bayonet female cable connector, Contacts: 6 DIN, 3.0 - 6.0 mm, unshielded, solder, IP40   Bayonet series 678 99 0618 00 06 Material Housing material PA Contact body material PBT (UL94 V-0) Contact material CuSn (bronze) Contact plating Ag (silver) REACH SVHC None (No pollutants) SCIP number SCIP-number not available Classifications eCl@ss 11.1 27-44-01-02 ETIM 7.0 EC002635 Declarations of conformity Low Voltage Directive 2014/35/EU (EN 60204-1:2018;EN 60529:1991) Component part drawing Date: 11.07.2021 Product data sheet Miniature connectors Product description   Area Order number Bayonet female cable connector, Contacts: 6 DIN, 3.0 - 6.0 mm, unshielded, solder, IP40   Bayonet series 678 99 0618 00 06 Security notices The connector must not be plugged or unplugged under load. Non-observance and improper use can result in personal injury. The connectors have been developed for applications in plant engineering, control and electrical equipment construction. The user is responsible for checking whether the connectors can also be used in other areas of application. Connectors which are used in circuits with voltages dangerous to the touch may only be installed and used by, or under the supervision of, persons with electrical engineering training, taking into account the applicable regulations and standards. The plug connector is not suitable for mains voltages Please observe the pollution degree and the overvoltage category. For further information, please refer to the download center "Technical Information". Date: 11.07.2021
99-0618-00-06 价格&库存
很抱歉,暂时无法提供与“99-0618-00-06”相匹配的价格&库存,您可以联系我们找货
