99-4221-00-04
99-4221-00-04
    BINDER(宾德)
99-4221-00-04 数据手册
Product sheet Power connectors Male cable connector with cable clamp, PG 9 with VDE, SEV, UL approval RD 24 connectors serie 693 illustration Pole Article number scale drawing Date: 2013-07-03 - Page 1 of 1 Product Area 3+PE 99 4221 00 04 Contact Arrangement Technical data Common values Material Connector Design Male cable connector Connector locking system Screw-locking Termination screw Wire gauge (mm) 0,5-2,5 mm² Wire gauge (AWG) 20-14 Max. Cable outlet 6 - 9,5 mm Upper temperature +100 °C Lower temperature -40 °C Material of contact CuZn (brass) Contact plating Ag (silver) Material of contact body PBT (UL 94 V-0) Material of housing PBT (UL 94 V 0) Cable data Contacts 3+PE, male cable connector with cable clamp, PG 9 with VDE, SEV, UL approval, screw Electrical values Rated voltage 600 V Rated impulse voltage 6000 V Pollution degree 3 Overvoltage category III Material group III Volume resistivity ≤ 5 mΩ EMV compliance not shielded Degree of protection IP 67 Mechanical operation >500 mating cycles Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de Powered by TCPDF (www.tcpdf.org) 99 4221 00 04
99-4221-00-04 价格&库存
很抱歉,暂时无法提供与“99-4221-00-04”相匹配的价格&库存,您可以联系我们找货
    • 1+206.40490
    • 50+204.62017
    • 100+201.31425
    • 250+197.62502
    • 500+193.75613
    库存:82
