99-5662-75-19
99-5662-75-19
    BINDER(宾德)
99-5662-75-19 数据手册
M16 IP67 Miniature 423 series • Screw termination M16 • Degree of protection IP67 • Solder-/Crimp-/Screw clamp termination • Moulded versions • shieldable • Acc. to DIN EN 61076-2-106 • AISG compatible certified under number 20120329-E30 2391 Description Drawing Contacts Cable outlet Shielding ring Cable clamp 4–6 mm 99 5105 15 03 99 5109 15 04 99 5113 15 05 99 5121 15 06 99 5125 15 07 99 5171 15 08 99 5129 15 12 99 5461 15 19 99 5105 00 03 99 5109 00 04 99 5113 00 05 99 5121 00 06 99 5125 00 07 99 5171 00 08 99 5129 00 12 99 5461 00 19 3 DIN 4 5 6 DIN 7 8 DIN 12 19 6–8 mm 99 5605 15 03 99 5609 15 04 99 5613 15 05 99 5621 15 06 99 5625 15 07 99 5671 15 08 99 5629 15 12 99 5661 15 19 99 5605 00 03 99 5609 00 04 99 5613 00 05 99 5621 00 06 99 5625 00 07 99 5671 00 08 99 5629 00 12 99 5661 00 19 Contacts Cable outlet Screw clamp Crimp 4–6 mm 99 5105 210 03 99 5109 210 04 99 5113 210 05 – – – – 99 5109 700 04 99 5113 700 05 99 5121 700 06 99 5125 700 07 99 5171 700 08 6–8 mm 99 5605 210 03 99 5609 210 04 99 5613 210 05 – – – – 99 5609 700 04 99 5613 700 05 99 5621 700 06 99 5625 700 07 99 5671 700 08 3 DIN 4 5 6 DIN 7 8 DIN 12 19 Male cable connector with shielding ring/cable clamp, shieldable, solder termination Ø 18,5 ~ 60 Male cable connector with shielding ring/cable clamp, shieldable, solder termination Ø 18,5 ~ 60 3 DIN 4 5 6 DIN 7 8 DIN Male cable connector with cable clamp, screw clamp connection/crimp connection, shieldable M16 x 0,75 Ø 18,5 ~ 60 Crimp and strip contacts see page 56 3 DIN 4 5 6 DIN 7 8 DIN Male cable connector with cable clamp, screw clamp connection/crimp connection, shieldable M16 x 0,75 Ø 18,5 ~ 60 Crimp and strip contacts see page 56 Specifications Contacts 3 DIN 4 5 6 DIN max. 0,75 mm (max. AWG 20) Wire gauge Mechanical operation 12 19 max. 0,25 mm (max. AWG 24) 2 – 40 °C /+ 95 °C Rated voltage 250 V (32 V) 125 V (32 V) Pollution degree 60 V (32 V) 1 (2) 1) 7A 6A Contact plating 5A Ag (Silver) Material of housing 49 8 DIN > 500 Mating cycles Temperature range Rated current (40°C) 7 2 3A Au (Gold) CuZn (brass, nickel plated) 1) In case of pollution degree 2, overvoltage category II rated voltage is reduced to 32 V.. More versions and information on www.binder-connector.com M16 IP67 Description Miniature 423 · 425 series Drawing Contacts Male cable connector, short version, solder termination Ø 18,5 M 16 x 0,75 Ø 4,1–7,8 ~ 45 4 5 6 DIN 7 8 DIN Male cable connector, short version, crimp connection Crimp and strip contacts see page 56 ~ 54 30,8 37,1 Ø 18 Male angled connector, shieldable, solder termination 3 DIN 4 5 6 DIN 7 8 DIN 12 19 Ordering-No. 4–8 mm 99 5105 40 03 99 5109 40 04 99 5113 40 05 99 5121 40 06 99 5125 40 07 99 5171 40 08 99 5129 40 12 99 5461 40 19 4–8 mm 99 5109 740 04 99 5113 740 05 99 5121 740 06 99 5125 740 07 99 5171 740 08 Contacts Cable outlet 4–6 mm Cable outlet 6–8 mm 3 DIN 4 5 6 DIN 7 8 DIN 12 19 99 5105 75 03 99 5109 75 04 99 5113 75 05 99 5121 75 06 99 5125 75 07 99 5171 75 08 99 5129 75 12 99 5461 75 19 99 5605 75 03 99 5609 75 04 99 5613 75 05 99 5621 75 06 99 5625 75 07 99 5671 75 08 99 5629 75 12 99 5661 75 19 4 5 6 DIN 7 8 DIN 99 5109 750 04 99 5113 750 05 99 5121 750 06 99 5125 750 07 99 5171 750 08 99 5609 750 04 99 5613 750 05 99 5621 750 06 99 5625 750 07 99 5671 750 08 20 M16 x 0,75 Cable outlet Male angled connector, shieldable, crimp connection Crimp and strip contacts see page 56 Contacts 5 x 0,25 6 DIN x 0,25 8 DIN x 0,25 12 x 0,25 Male cable connector, moulded 50,8 L Unshielded Shielded 2m 79 6013 20 05 – 79 6071 20 08 79 6029 20 12 79 6113 20 05 79 6117 20 06 79 6171 20 08 79 6129 20 12 2m 79 6213 200 05 – 79 6271 200 08 79 6229 200 12 79 6313 200 05 79 6317 200 06 79 6371 200 08 79 6329 200 12 Ø 18,5 30,8 Cable length, PUR 52 L 5 x 0,25 6 DIN x 0,25 8 DIN x 0,25 12 x 0,25 35,3 18,8 41,5 Ø 14 Ø 17 21,6 Male angled connector, moulded Ø 20 M16 x 0,75 50 M16 IP67 Description Miniature 423 series Drawing Contacts Cable outlet Shielding ring cable clamp 4–6 mm 99 5106 15 03 99 5110 15 04 99 5114 15 05 99 5122 15 06 99 5126 15 07 99 5172 15 08 99 5130 15 12 99 5462 15 19 99 5106 00 03 99 5110 00 04 99 5114 00 05 99 5122 00 06 99 5126 00 07 99 5172 00 08 99 5130 00 12 99 5462 00 19 3 DIN 4 5 6 DIN 7 8 DIN 12 19 6–8 mm 99 5606 15 03 99 5610 15 04 99 5614 15 05 99 5622 15 06 99 5626 15 07 99 5672 15 08 99 5630 15 12 99 5662 15 19 99 5606 00 03 99 5610 00 04 99 5614 00 05 99 5622 00 06 99 5626 00 07 99 5672 00 08 99 5630 00 12 99 5662 00 19 Contacts Cable outlet Screw clamp Crimp 4–6 mm 99 5106 210 03 99 5110 210 04 99 5114 210 05 – – – – 99 5110 700 04 99 5114 700 05 99 5122 700 06 99 5126 700 07 99 5172 700 08 3 DIN 4 5 6 DIN 7 8 DIN 6–8 mm 99 5606 210 03 99 5610 210 04 99 5614 210 05 – – – – 99 5610 700 04 99 5614 700 05 99 5622 700 06 99 5626 700 07 99 5672 700 08 Contacts Cable outlet Ordering-No. 4–8 mm 99 5106 40 03 99 5110 40 04 99 5114 40 05 99 5122 40 06 99 5126 40 07 99 5172 40 08 99 5130 40 12 99 5462 40 19 4–8 mm 99 5110 740 04 99 5114 740 05 99 5122 740 06 99 5126 740 07 99 5172 740 08 3 DIN 4 5 6 DIN 7 8 DIN 12 19 Female cable connector with shielding ring/cable clamp, shieldable Ø 18,5 ~ 60 Female cable connector with shielding ring/cable clamp, shieldable Ø 18,5 ~ 60 3 DIN 4 5 6 DIN 7 8 DIN Female cable connector with cable clamp, screw clamp connection/crimp connection, shieldable M16 x 0,75 Ø 18,5 ~ 60 Crimp and strip contacts see page 56 Female cable connector with cable clamp, screw clamp connection/crimp connection, shieldable M16 x 0,75 Ø 18,5 ~ 60 Female cable connector, short version, solder termination M16 x 0,75 Female cable connector, short version, crimp connection 51 Ø 4,1–7,8 Ø 4,1–7,8 Ø 18,5 ~ 45 3 DIN 4 5 6 DIN 7 8 DIN 12 19 4 5 6 DIN 7 8 DIN M16 IP67 Miniature 423 · 425 series Description Drawing Female angled connector, shieldable ~ 54 37,4 Ø 18 30,8 Cable outlet 4–6 mm Cable outlet 6–8 mm 3 DIN 4 5 6 DIN 7 8 DIN 12 19 99 5106 75 03 99 5110 75 04 99 5114 75 05 99 5122 75 06 99 5126 75 07 99 5172 75 08 99 5130 75 12 99 5462 75 19 99 5606 75 03 99 5610 75 04 99 5614 75 05 99 5622 75 06 99 5626 75 07 99 5672 75 08 99 5630 75 12 99 5662 75 19 4 5 6 DIN 7 8 DIN 99 5110 750 04 99 5114 750 05 99 5122 750 06 99 5126 750 07 99 5172 750 08 99 5610 750 04 99 5614 750 05 99 5622 750 06 99 5626 750 07 99 5672 750 08 20 M16 x 0,75 Contacts Female angled connector, crimp connection, shieldable Crimp and strip contacts see page 56 Contacts 5 x 0,25 6 DIN x 0,25 8 DIN x 0,25 12 x 0,25 Female cable connector, moulded 51,2 L Unshielded Shielded 2m 79 6014 20 05 – 79 6072 20 08 79 6030 20 12 79 6114 20 05 79 6118 20 06 79 6172 20 08 79 6130 20 12 2m 79 6214 200 05 – 79 6272 200 08 79 6230 200 12 79 6314 200 05 79 6318 200 06 79 6372 200 08 79 6330 200 12 Ø 18,5 31,2 Cable length, PUR 21,6 Ø 14 Ø 17 Female angled connector, moulded 52 L 35,6 18,8 41,5 5 x 0,25 6 DIN x 0,25 8 DIN x 0,25 12 x 0,25 Ø 20 Component part drawing Cable connectors, solder termination, with shielding ring Cable connectors with screw clamp connection Male ring nut/ Female ring nut with seal Female insert/ Male insert Distance sleeve Shielding ring Shield clamping ring Sleeve Seal Pinch ring Pressing screw Cable connectors, solder termination, with cable clamp Male ring nut/ Female ring nut with seal Female insert/ Male insert Cable clamp Sleeve Seal Thrust collar Pressing screw Male ring nut/ Female ring nut with seal Female insert/ Male insert Cable clamp Sleeve Seal Thrust collar Pressing screw Cable connectors with crimp connection Male ring nut/ Female ring nut Female insert/ Male insert Female contact/ Male contact Cable clamp Sleeve Seal Thrust collar Pressing screw 52 M16 IP67 Miniature 423 · 723 series Component part drawing Cable connectors, short version Male ring nut/ Female ring nut with seal Female insert/ Male insert Cable clamp Seal 4–6 mm/6–8 mm Pressing screw Description Drawing Angled connectors Male cable connector, solder termination Ø 21,5 M16 x 0,75 ~68 Male angled connector, solder termination 45,5 38 28,5 Ø 19 ~ 32 Male ring nut and housing/ Female ring nut and housing with seal Positioning sleeve with O-ring 12,5 x 1,1 Female insert/ Male insert Distance sleeve, Shaped seal, Cover O-ring 9 x 1,5 Shielding ring, Seal Pinch ring, Pressing screw Cable outlet adjustable in 4 positions Contacts Cable outlet 4–6 mm Cable outlet 6–8 mm 3 DIN 4 5 6 DIN 7 8 DIN 12 19 09 0105 25 03 09 0109 25 04 09 0113 25 05 09 0121 25 06 09 0125 25 07 09 0171 25 08 09 0129 25 12 09 0461 25 19 09 0105 70 03 09 0109 70 04 09 0113 70 05 09 0121 70 06 09 0125 70 07 09 0171 70 08 09 0129 70 12 09 0461 70 19 3 DIN 4 5 6 DIN 7 8 DIN 12 19 99 0105 106 03 99 0109 106 04 99 0113 106 05 99 0121 106 06 99 0125 106 07 99 0171 106 08 99 0129 106 12 99 0461 106 19 99 0105 75 03 99 0109 75 04 99 0113 75 05 99 0121 75 06 99 0125 75 07 99 0171 75 08 99 0129 75 12 99 0461 75 19 3 DIN 4 5 6 DIN 7 8 DIN 12 19 09 0106 25 03 09 0110 25 04 09 0114 25 05 09 0122 25 06 09 0126 25 07 09 0172 25 08 09 0130 25 12 09 0462 25 19 09 0106 70 03 09 0110 70 04 09 0114 70 05 09 0122 70 06 09 0126 70 07 09 0172 70 08 09 0130 70 12 09 0462 70 19 3 DIN 4 5 6 DIN 7 8 DIN 12 19 99 0106 106 03 99 0110 106 04 99 0114 106 05 99 0122 106 06 99 0126 106 07 99 0172 106 08 99 0130 106 12 99 0462 106 19 99 0106 75 03 99 0110 75 04 99 0114 75 05 99 0122 75 06 99 0126 75 07 99 0172 75 08 99 0130 75 12 99 0462 75 19 M16 x 0,75 Ø 24 Female cable connector, solder termination Ø 21,5 M16 x 0,75 ~66 Female angled connector, solder termination 43,5 34 Ø 19 ~ 32 M16 x 0,75 Ø 24 Component part drawing Cable connectors 53 Male ring nut/ Female ring nut with seal Female insert assembled/ Male insert assembled Housing Seal Pinch ring Pressing screw Angled connectors Male ring nut/ Female ring nut Female insert/ Male insert Angled housing Seal Pinch ring Pressing screw Cable outlet adjustable in 4 positions M16 IP67 Miniature Series 723 Description Drawing Male panel mount connector, solder/with single wires (200 mm), AWG 22 Ø 20 M16 x 0,75 M18 x 0,75 Ø 20 16 9,5 3 1,5 1 min. 3 max. 2–8 pol. 12–24 pol. 1,5 2–8 pol. Ø 20 1,5 8,1 3,5 Ø 20 M18 x 0,75 M16 x 0,75 16,5 15 7 Ø 0,75 Ø 0,6 3 Male panel mount connector with single wires 09 0107 00 03 09 0111 00 04 09 0115 00 05 09 0123 00 06 09 0127 00 07 09 0173 00 08 09 0131 00 12 09 0463 00 19 – 09 0111 702 04 09 0115 702 05 09 0123 702 06 09 0127 702 07 09 0173 702 08 – – 3 DIN 4 5 6 DIN 7 8 DIN 12 19 09 0107 80 03 09 0111 80 04 09 0115 80 05 09 0123 80 06 09 0127 80 07 09 0173 80 08 09 0131 80 12 09 0463 80 19 – 09 0111 782 04 09 0115 782 05 09 0123 782 06 09 0127 782 07 09 0173 782 08 – – 3 DIN 4 5 6 DIN 7 8 DIN 12 19 09 0107 90 03 09 0111 90 04 09 0115 90 05 09 0123 90 06 09 0127 90 07 09 0173 90 08 09 0131 90 12 09 0463 90 19 5 6 DIN 8 DIN 12 19 09 0115 290 05 09 0123 290 06 09 0173 290 08 09 0131 290 12 09 0463 290 19 4 5 6 DIN 7 8 DIN 09 0111 700 04 09 0115 700 05 09 0123 700 06 09 0127 700 07 09 0173 700 08 4 5 6 DIN 7 8 DIN 09 0111 780 04 09 0115 780 05 09 0123 780 06 09 0127 780 07 09 0173 780 08 1 min. 3,5 max. 7,8 1 min. 3,5 max. Male panel mount connector, dip-solder, front fastened, with shield connection 15 9,6 7 7,1 2–8 pol. 3,5 Ø 0,75 Male panel mount connector, dip-solder, front fastened 12–24 pol. Ø 20 Ø 20 M18 x 0,75 M16 x 0,75 3 Male panel mount connector solder 3 DIN 4 5 6 DIN 7 8 DIN 12 19 3 Male panel mount connector, solder, front fastened/with single wires (200 mm), AWG 22 16,5 15 7 Contacts 12–24 pol. Ø 20 M18 x 0,75 M16 x 0,75 Ø 0,75 3,5 1 5–8 pol. 3 12 pol. 9,4 1 min. 3,5 max. Male panel mount connector, crimp M18 x 0,75 Ø 20 Ø 20 M16 x 0,75 21,4 16 9,5 3 1,5 1 min. 3,5 max. Crimp and strip contacts see page 56 21,4 16,5 7 3 Crimp and strip contacts see page 56 Ø 20 Ø 20 M18 x 0,75 M16 x 0,75 Male panel mount connector, crimp, front fastened 1 min. 3,5 max. 1,5 54 M16 IP67 Miniature Series 723 Description Drawing Female panel mount connector, solder/with single wires (200 mm), AWG 22 12,2 10,1 1,5 8,6 5,5 Ø 20 M16 x 0,75 M18 x 0,75 3–7 pol. 5+8 pol. 12+19 pol. 3 1 min. 5 max. 3 Female panel mount connector, dip-solder, front fastened 3–7 pol. Ø 20 Ø 20 M18 x 0,75 Female panel mount connector, solder, front fastened/with single wires (200 mm), AWG 22 12,5 12,2 1,5 7,5 4,7 5,5 5+8 pol. 3–7 pol. Ø 20 M16 x 0,75 M18 x 0,75 4,5 3 1 x 0,3 5+8 pol. Female panel mount connector, crimp Ø 20 M18 x 0,75 Ø 20 14,8 11,8 3 Female panel mount connector, crimp, front fastened 1 min. 5 max. 12,5 4,5 7,8 4,7 7,5 1,5 3 1 x 0,3 Ø 20 Ø 0,75 Ø 20 Ø 20 M18 x 0,75 M16 x 0,75 Ø 20 M18 x 0,75 09 0108 80 03 09 0112 80 04 09 0116 80 05 09 0124 80 06 09 0128 80 07 09 0174 80 08 09 0132 80 12 09 0464 80 19 – 09 0112 782 04 09 0116 782 05 09 0124 782 06 09 0128 782 07 09 0174 782 08 – – 3 DIN 4 5 6 DIN 7 8 DIN 12 19 09 0108 90 03 09 0112 90 04 09 0116 90 05 09 0124 90 06 09 0128 90 07 09 0174 90 08 09 0132 90 12 09 0464 90 19 4 5 6 DIN 7 8 DIN 09 0112 700 04 09 0116 700 05 09 0124 700 06 09 0128 700 07 09 0174 700 08 4 5 6 DIN 7 8 DIN 09 0112 780 04 09 0116 780 05 09 0124 780 06 09 0128 780 07 09 0174 780 08 1,5 Male panel mount connector/Female panel mount connector with flexible PCB, front fastened 16,5 1,5 15 7 8,1 3,5 55 3 DIN 4 5 6 DIN 7 8 DIN 12 19 Ø 20 Ø 20 M18 x 0,75 14,8 11,8 7,5 3 3 ~3,5 – 09 0112 702 04 09 0116 702 05 09 0124 702 06 09 0128 702 07 09 0174 702 08 – – 1 min. 5 max. Crimp and strip contacts see page 56 Crimp and strip contacts see page 56 09 0108 00 03 09 0112 00 04 09 0116 00 05 09 0124 00 06 09 0128 00 07 09 0174 00 08 09 0132 00 12 09 0464 00 19 12+19 pol. 1 min. 4 max. 1,5 Female panel mount connector solder Female panel mount connector with single wires 3 DIN 4 5 6 DIN 7 8 DIN 12 19 12+19 pol. 1 min. 4 max. 12,5 7,8 4,7 7,5 1,5 3 Contacts 0,25 3 1 min. 3,5 max. 1 min. 4 max. 0,25 7 8 DIN 12 Male panel mount connector Female panel mount connector 09 0127 65 07 09 0173 65 08 09 0131 65 12 single-row 09 0131 66 12 double-row 09 0128 65 07 09 0174 65 08 09 0132 65 12 single-row 09 0132 66 12 double-row M16 IP67 Miniature 423 · 723 · 425 series Contact arrangements male insert (mating side) 3 DIN contacts 4 contacts 6 DIN contacts 3 2 3 1 2 4 4 1 5 3 4 2 8 DIN contacts 4 3 6 1 6 1 1 8 7 6 19 contacts G E 4 3 7 2 12 contacts 2 5 5 2 5 1 7 contacts D F C L A B D H M C J K B E F P O N R S T M U A L G H I 3 5 contacts K Contact arrangements female insert (mating side) 2 3 Panel cut out 3 3 1 3 2 4 4 1 2 8,3 Recommended drill holes 2 – 8 contacts 12 – 24 contacts 5 4 3 5 7 6 2 4 2 1 1 1,1 mm 0,8 mm 8 6 Colour of wires of moulded cable connectors 5 contacts 6 contacts 8 contacts 12 contacts 1 white 1 red 1 white A white 2 brown 2 black 2 brown B brown 3 blue 3 yellow 3 green C green 4 black 4 blue 4 yellow D yellow 5 grey 5 white 5 grey E grey 6 green 6 pink F pink 7 blue G blue 8 red H red Ø 18 17 R2 Description 6 1 5 4 J K L M 5 H 3 M J 7 black purple grey/pink red/blue G A K E F G D L H I 1 2 C K B F E R P S T L D O N U M C B A Colour of wires of panel mount connectors 4–8 contacts 1 white 2 brown 3 green 4 yellow 5 grey 6 pink 7 blue 8 red Drawing Male contact, PU 50 pieces 20,5 Ø 2,25 Ø 1,5 9,2 Female contact, PU 50 pieces Ø 2,25 14,3 8,1 Contact-Ø Insulating-Ø Wire gauge Strip contact (Male) 0,14–0,25 mm2 1,0–2,0 mm 1,5 mm 0,35–0,5 mm2 1,6–2,1 mm 0,75–1,0 mm2 Strip contact (Female) 0,14–0,25 mm2 1,0–2,0 mm 1,5 mm 0,35–0,5 mm2 1,6–2,1 mm 0,75–1,0 mm2 PU Pieces Ordering-No. Single Strip Strip Single Strip Strip Single Strip Strip 50 200 2000 50 200 2000 50 200 2000 61 0799 085 00 65 0799 085 01 65 0799 085 02 61 0795 085 00 65 0795 085 01 65 0795 085 02 61 0796 085 00 65 0796 085 01 65 0796 085 02 Single Strip Strip Single Strip Strip Single Strip Strip 50 200 2000 50 200 2000 50 200 2000 61 0800 085 00 65 0800 085 01 65 0800 085 02 61 0797 085 00 65 0797 085 01 65 0797 085 02 61 0798 085 00 65 0798 085 01 65 0798 085 02 56 M16 IP67 Description Miniature 423 · 723 · 425 series Ordering-No. Drawing 08 1077 000 000 Protection cap for male cable connectors ~ 125 10,5 5 Ø6 Ø 20 08 1078 000 000 Protection cap for female cable connectors ~ 125 7 5 13,5 Ø6 Ø 20 Protection cap for male panel mount connectors 70 Hole-Ø D Ordering-No. 3 mm 18 mm 08 1079 000 000 08 2670 000 000 3 mm 18 mm 08 1080 000 000 08 2671 000 000 10,5 5 Ø6 ØD Ø 20 Protection cap for female panel mount connectors 70 5 7 13,5 Ø6 ØD Ø 20 Ordering-No. 07 0010 001 Mounting spanner for panel mount connectors 1,5 25 45 08 0045 000 001 8,4 20 26 Ø 18,1 Rectangular flange for panel mount connectors Ø 3,2 1 01 0010 001 with knurled screw 20 1 Ring nut for fixing thread M18 x 0,75 57 3 1 M16 IP67 Miniature 423 · 723 · 425 series Description Drawing Hexagonal nut 2,5 M18 x 0,75 5 Thickness Ordering-No. 2,5 mm 5 mm 01 0146 001 01 5006 001 SW 20mm Ordering-No. Solder eye ring 04 0186 009 13 0,7 3 2 4,8 Ø 18 Ø 22 22 08 2668 000 001 Blind plug 12 0,3 min./4 max. Ø 21 M18 x 0,75 9 3 3 02 0007 000 Distance sleeve for panel mount connectors, dip-solder version 6,4 Ø 21,5 PCB thickness: max. Leiterplattendicke: max.1,5 1,5mm mm Thickness of PCB: max. 1,5 mm 02 1785 000 20 Mounting spanner for straight, shieldable cable connectors 8 Crimping tool for single contacts Extraction tool for crimp contacts Crimping tool for strip contacts 31,5 10,5 66 0001 014 100 67 0001 014 100 07 0088 000 58
99-5662-75-19 价格&库存
很抱歉,暂时无法提供与“99-5662-75-19”相匹配的价格&库存,您可以联系我们找货
