99-9225-00-08
99-9225-00-08
    BINDER(宾德)
99-9225-00-08 数据手册
Product data sheet Subminiature Product description Contacts: 8, cable plug connector Area Order number Snap-in IP67 Series 620 99 9225 00 08 Illustration Scale drawing Contact arrangement You can find the component part drawing on the next page. Technical data General values Connector design Connector locking system Termination Wire gauge (mm) Wire gauge (AWG) Cable outlet Upper limit temperature Lower limit temperature Electrical values cable connector snap löten 0,25 mm² 24 3,0 - 5,0 mm 85 °C -25 °C Rated voltage Rated impulse voltage Pollution degree Overvoltage category Insulating material group Rated current (40 °C) Volume resistivity EMC compliance Degree of protection Mechanical operation 63 V 800 V 2 II II 1A ≤ 3 mΩ Shielding is not possible IP67 > 500 Mating cycles Material Contact material Contact plating Contact body material CuZn (brass) Au (gold) PA (UL 94 V-0) Date: 2018-02-05 - Page 1 of 3 Product data sheet Subminiature Product description Contacts: 8, cable plug connector Area Order number Snap-in IP67 Series 620 99 9225 00 08 Component part drawing Date: 2018-02-05 - Page 2 of 3 Powered by TCPDF (www.tcpdf.org) Product data sheet Subminiature Product description Contacts: 8, cable plug connector Area Order number Snap-in IP67 Series 620 99 9225 00 08 Sicherheitshinweise The connectors are designed for use in plant, control system and electrical equipment. The end user is responsible for checking whether the connectors are suitable for use in other applications. Connectors with degree of protection IP 67 and IP 68 are not suitable for use under water. When used outdoors, the connectors must be separately protected against corrosion. For further information about IP degrees of protection refer to ‘Technical support’ in the Download Centre. Date: 2018-02-05 - Page 3 of 3
99-9225-00-08 价格&库存
很抱歉,暂时无法提供与“99-9225-00-08”相匹配的价格&库存,您可以联系我们找货
  • 1+81.62366
  • 10+80.54062
  • 50+78.94730
  • 100+77.29150
  • 250+75.62529
库存:1
99-9225-00-08
  • 10+80.54062
  • 50+78.94730
  • 100+77.29150
  • 250+75.62529
库存:43
99-9225-00-08
  • 1+96.72348
  • 10+95.44206
  • 100+91.58594
  • 250+89.61635
  • 500+87.82473
  • 1000+86.03312
库存:268
