9904301404
9904301404
    BINDER(宾德)
    BINDER - 9904301404 - Circular Connector, 713 Series, Cable Mount Receptacle, 4 Contacts, Screw Sock...
9904301404 数据手册
Product sheet Automation technology Female cable connector, metal locking system, screw termination M12 connectors A-Coding serie 713 illustration Pole Article number scale drawing Date: 2013-08-16 - Page 1 of 2 Product Area 4 99 0430 14 04 Contact Arrangement You can find the item description and assembly instruction on the next page. Technical data Common values Material Connector Design Female cable connector Connector locking system Screw-locking Termination screw Wire gauge (mm) 0,75 mm² Wire gauge (AWG) 18 Upper temperature +85 °C Lower temperature -40 °C Cable data Rated voltage 250 V Contacts 4: cable outlet: 4-6 mm, Female cable connector, metal locking system, screw termination Rated impulse voltage 2500 V Pollution degree 3 Overvoltage category II Material group II Rated current (40°C) 4A Volume resistivity ≤ 8 mΩ Degree of protection IP 67 Mechanical operation > 50 mating cycles Electrical values Material of contact CuZn (brass) Contact plating CuSnZn (Optalloy) Material of contact body PA Material of housing PA Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de 99 0430 14 04 Product sheet Automation technology Female cable connector, metal locking system, screw termination M12 connectors A-Coding serie 713 Pole Article number Date: 2013-08-16 - Page 2 of 2 Product Area 4 99 0430 14 04 Item description Installation instructions / Mounting cutout Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de Powered by TCPDF (www.tcpdf.org) 99 0430 14 04
9904301404 价格&库存
很抱歉,暂时无法提供与“9904301404”相匹配的价格&库存,您可以联系我们找货
