09 0301 00 02
09 0301 00 02
    BINDER(宾德)
    BINDER - 09 0301 00 02 - Circular Connector, 680 Series, Cable Mount Plug, 2 Contacts, Solder Pin, N...
09 0301 00 02 数据手册
Product sheet Miniature connectors Male cable connector, cable outlet 3-6 mm M16 connectors IP 40 illustration Pole Article number serie 680 scale drawing Date: 2013-08-16 - Page 1 of 2 Product Area 2 09 0301 00 02 Contact Arrangement You can find the item description on the next page. Technical data Common values Material Connector Design Male cable connector Connector locking system Screw-locking Termination solder Wire gauge (mm) 0,75 mm² Wire gauge (AWG) 20 Max. Cable outlet 3 - 6 mm Upper temperature +85 °C Lower temperature -40 °C Material of contact CuZn (brass) Contact plating Ag (silver) Material of contact body PBT (UL 94 V-0) Material of housing PA (UL 94 HB) Cable data Contacts 2, male cable connector, cable outlet 3 – 6 mm, silver plated contacts Electrical values Rated voltage 250 V Rated impulse voltage 1500 V Pollution degree 1 Overvoltage category I Material group III Rated current (40°C) 7A Volume resistivity ≤ 5 mΩ EMV compliance not shielded Degree of protection IP 40 Mechanical operation >500 mating cycles Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de 09 0301 00 02 Product sheet Miniature connectors Male cable connector, cable outlet 3-6 mm M16 connectors IP 40 serie 680 Pole Article number Date: 2013-08-16 - Page 2 of 2 Product Area 2 09 0301 00 02 Item description Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de Powered by TCPDF (www.tcpdf.org) 09 0301 00 02
09 0301 00 02 价格&库存
很抱歉,暂时无法提供与“09 0301 00 02”相匹配的价格&库存,您可以联系我们找货
