09 0306 00 03
09 0306 00 03
    BINDER(宾德)
    BINDER - 09 0306 00 03 - Circular Connector, 680 Series, 3 Contacts, Nylon (Polyamide) Body
09 0306 00 03 数据手册
Product sheet Miniature connectors Female cable connector, cable outlet 3-6 mm M16 connectors IP 40 illustration Pole Article number serie 680 scale drawing Date: 2013-07-15 - Page 1 of 2 Product Area 3 DIN 09 0306 00 03 Contact Arrangement You can find the item description on the next page. Technical data Common values Material Connector Design Female cable connector Connector locking system Screw-locking Termination solder Wire gauge (mm) 0,75 mm² Wire gauge (AWG) 20 Max. Cable outlet 3 - 6 mm Upper temperature +85 °C Lower temperature -40 °C Material of contact CuSn (bronce) Contact plating Ag (silver) Material of contact body PBT (UL 94 V-0) Material of housing PA (UL 94 HB) Cable data Contacts 3 DIN, female cable connector, cable outlet 3 – 6 mm, silver plated contacts Electrical values Rated voltage 250 V Rated impulse voltage 1500 V Pollution degree 1 Overvoltage category I Material group III Rated current (40°C) 7A Volume resistivity ≤ 5 mΩ EMV compliance not shielded Degree of protection IP 40 Mechanical operation >500 mating cycles Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de 09 0306 00 03 Product sheet Miniature connectors Female cable connector, cable outlet 3-6 mm M16 connectors IP 40 serie 680 Pole Article number Date: 2013-07-15 - Page 2 of 2 Product Area 3 DIN 09 0306 00 03 Item description Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de Powered by TCPDF (www.tcpdf.org) 09 0306 00 03
09 0306 00 03 价格&库存
很抱歉,暂时无法提供与“09 0306 00 03”相匹配的价格&库存,您可以联系我们找货
  • 1+84.130021+10.91580
  • 5+75.769275+9.83100
  • 20+67.3214420+8.73490
  • 100+58.96069100+7.65010
库存:79
