09 0310 00 04
09 0310 00 04
    BINDER(宾德)
    BINDER - 09 0310 00 04 - Circular Connector, 680 Series, Cable Mount Receptacle, 4 Contacts, Solder ...
09 0310 00 04 数据手册
Product sheet Miniature connectors Female cable connector, cable outlet 3-6 mm M16 connectors IP 40 illustration Pole Article number serie 680 scale drawing Date: 2013-06-04 - Page 1 of 2 Product Area 4 09 0310 00 04 Contact Arrangement You can find the item description on the next page. Technical data Common values Material Connector Design Female cable connector Connector locking system Screw-locking Termination solder Wire gauge (mm) 0,75 mm² Wire gauge (AWG) 20 Max. Cable outlet 3 - 6 mm Upper temperature +85 °C Lower temperature -40 °C Material of contact CuSn (bronce) Contact plating Ag (silver) Material of contact body PBT (UL 94 V-0) Material of housing PA (UL 94 HB) Cable data Contacts 4, female cable connector, cable outlet 3 – 6 mm, silver plated contacts Electrical values Rated voltage 250 V Rated impulse voltage 1500 V Pollution degree 1 Overvoltage category I Material group III Rated current (40°C) 6A Volume resistivity ≤ 5 mΩ EMV compliance not shielded Degree of protection IP 40 Mechanical operation >500 mating cycles Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de 09 0310 00 04 Product sheet Miniature connectors Female cable connector, cable outlet 3-6 mm M16 connectors IP 40 serie 680 Pole Article number Date: 2013-06-04 - Page 2 of 2 Product Area 4 09 0310 00 04 Item description Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de Powered by TCPDF (www.tcpdf.org) 09 0310 00 04
09 0310 00 04 价格&库存
很抱歉,暂时无法提供与“09 0310 00 04”相匹配的价格&库存,您可以联系我们找货
  • 1+86.283831+11.15310
  • 5+77.716645+10.04570
  • 20+69.0620320+8.92700
  • 100+60.40742100+7.80830
库存:48
