Product sheet
Miniature connectors
Male cable connector, cable outlet 3-6 mm
M16 connectors IP 40
illustration
Pole
Article number
serie 680
scale drawing
Date: 2013-11-06 - Page 1 of 2
Product
Area
7
09 0325 00 07
Contact Arrangement
You can find the item description on the next page.
Technical data
Common values
Material
Connector Design
Connector locking system
Screw-locking
Termination
solder
Wire gauge (mm)
0,75 mm²
Wire gauge (AWG)
Cable outlet
3 - 6 mm
Upper temperature
+85 °C
Lower temperature
-40 °C
Material of contact
CuZn (brass)
Contact plating
Ag (silver)
Material of contact body
PBT (UL 94 V-0)
Material of housing
PA (UL 94 HB)
Cable data
Contacts 7, male cable connector, cable outlet
3 – 6 mm, silver plated contacts
Electrical values
Rated voltage
125 V
Rated impulse voltage
800 V
Pollution degree
1
Overvoltage category
I
Material group
III
Rated current (40°C)
5A
Volume resistivity
≤ 5 mΩ
EMV compliance
not shielded
Degree of protection
IP 40
Mechanical operation
>500 mating cycles
Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de
09 0325 00 07
Product sheet
serie 680
Pole
Article number
Date: 2013-11-06 - Page 2 of 2
Product
Area
7
09 0325 00 07
Item description
Powered by TCPDF (www.tcpdf.org)
09 0325 00 07
很抱歉,暂时无法提供与“09 0325 00 07”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+100.116871+12.91590
- 5+90.043875+11.61640
- 20+80.0584620+10.32820
- 100+70.16064100+9.05130
