09 0572 00 08
09 0572 00 08
    BINDER(宾德)
    BINDER - 09 0572 00 08 - Circular Connector, 680 Series, Cable Mount Receptacle, 8 Contacts, Solder ...
09 0572 00 08 数据手册
Product sheet Miniature connectors Female cable connector, cable outlet 3-6 mm M16 connectors IP 40 illustration Pole Article number serie 680 scale drawing Date: 2013-12-05 - Page 1 of 2 Product Area 8 DIN 09 0572 00 08 Contact Arrangement You can find the item description on the next page. Technical data Common values Material Connector Design Female cable connector Connector locking system Screw Termination solder Wire gauge (mm) 0,75 mm² Wire gauge (AWG) 20 Cable outlet 3 - 6 mm Upper temperature +85 °C Lower temperature -40 °C Material of contact CuSn (bronce) Contact plating Ag (silver) Material of contact body PBT (UL 94 V-0) Material of housing PA (UL 94 HB) Cable data Contacts 8 DIN, female cable connector, cable outlet 3 – 6 mm, silver plated contacts Electrical values Rated voltage 60 V Rated impulse voltage 500 V Pollution degree 1 Overvoltage category I Material group III Rated current (40°C) 5A Volume resistivity ≤ 5 mΩ EMV compliance not shielded Degree of protection IP 40 Mechanical operation >500 mating cycles Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de 09 0572 00 08 Product sheet Miniature connectors Female cable connector, cable outlet 3-6 mm M16 connectors IP 40 serie 680 Pole Article number Date: 2013-12-05 - Page 2 of 2 Product Area 8 DIN 09 0572 00 08 Item description Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de Powered by TCPDF (www.tcpdf.org) 09 0572 00 08
09 0572 00 08 价格&库存
很抱歉,暂时无法提供与“09 0572 00 08”相匹配的价格&库存,您可以联系我们找货
