76-0232-0011-00005-0200
    BINDER(宾德)
    BINDER - 76-0232-0011-00005-0200 - Sensor Cable, M12 Straight Receptacle to Free End, 200 mm, 7.9 ",...
76-0232-0011-00005-0200 数据手册
Product data sheet Automation technology - sensors and actuators Product description   Area Order number Illustration M12-A female panel mount connector, Contacts: 5, unshielded, single wires, IP68, M16x1.5   M12-A series 763 76 0232 0011 00005-0200 Scale drawing Contact arrangement (Plug-in side) You can find the assembly instructions on the next page. Technical data General features Order number 76 0232 0011 00005-0200 Alternative order number: 09 3442 700 05 Notice Please note that, due to the change from the old to the new order number, there may be deviations in the technical specifications. For questions about product details, please use the ‘Contact Customer Service’ form on the right. Connector design female panel mount connector Wire length 0,2 m Version connector female straight Connector locking system screw Termination single wires Degree of protection IP68 Cross-sectional area 0.25 mm² / AWG 24 Temperature range from/to -40 °C / 85 °C Mechanical operation > 100 Mating cycles Weight (g) 14 Customs tariff number 85369010 Electrical parameters Rated voltage 60 V Rated impulse voltage 1500 V Rated current (40 °C) 4A Insulation resistance > 10⁸ Ω Date: 12.06.2021 Product data sheet Automation technology - sensors and actuators Product description   Area Order number M12-A female panel mount connector, Contacts: 5, unshielded, single wires, IP68, M16x1.5   M12-A series 763 76 0232 0011 00005-0200 Pollution degree 3 Overvoltage category II Insulating material group III EMC compliance unshielded Material Housing material Zinc die-cast nickel-plated Contact body material PA black Contact material CuSn (bronze) Contact plating Au (gold) REACH SVHC CAS 7439-92-1 (Lead) Assembly instructions / Panel cut-out Date: 12.06.2021 Product data sheet Automation technology - sensors and actuators Product description   Area Order number M12-A female panel mount connector, Contacts: 5, unshielded, single wires, IP68, M16x1.5   M12-A series 763 76 0232 0011 00005-0200 Security notices The connector must not be plugged or unplugged under load. Non-observance and improper use can result in personal injury. The connectors have been developed for applications in plant engineering, control and electrical equipment construction. The user is responsible for checking whether the connectors can also be used in other areas of application. Plug connectors with enclosure protection IP 67 and IP 68 are not suitable for use under water. When used outdoors, the plug connectors must be protected separately against corrosion. For further information on the IP protection classes, please refer to the "Technical Information" download centre. Date: 12.06.2021
76-0232-0011-00005-0200 价格&库存
很抱歉,暂时无法提供与“76-0232-0011-00005-0200”相匹配的价格&库存,您可以联系我们找货
  • 1+100.91009
  • 10+92.77688
  • 25+83.80015
库存:50
