99-0429-14-04
99-0429-14-04
    BINDER(宾德)
99-0429-14-04 数据手册
Product sheet Automation technology Male cable connector, metal locking system, screw termination M12 connectors A-Coding serie 713 illustration Pole Article number scale drawing Date: 2013-12-05 - Page 1 of 2 Product Area 4 99 0429 14 04 Contact Arrangement You can find the item description and assembly instruction on the next page. Technical data Common values Material Connector Design Male cable connector Connector locking system Screw Termination screw Wire gauge (mm) 0,75 mm² Wire gauge (AWG) 18 Cable outlet 4 - 6 mm Upper temperature +85 °C Lower temperature -40 °C Material of contact CuZn (brass) Contact plating CuSnZn (Optalloy) Material of contact body PA Material of housing PA Cable data Contacts 4: cable outlet: 4–6 mm, Male cable connector, metal locking system, screw termination Electrical values Rated voltage 250 V Rated impulse voltage 2500 V Pollution degree 3 Overvoltage category II Material group III Rated current (40°C) 4A Volume resistivity ≤ 8 mΩ Degree of protection IP 67 Mechanical operation >100 mating cycles Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de 99 0429 14 04 Product sheet Automation technology Male cable connector, metal locking system, screw termination M12 connectors A-Coding serie 713 Pole Article number Date: 2013-12-05 - Page 2 of 2 Product Area 4 99 0429 14 04 Item description Installation instructions / Mounting cutout Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de Powered by TCPDF (www.tcpdf.org) 99 0429 14 04
99-0429-14-04 价格&库存
很抱歉,暂时无法提供与“99-0429-14-04”相匹配的价格&库存,您可以联系我们找货
