99-1430-814-04
99-1430-814-04
    BINDER(宾德)
99-1430-814-04 数据手册
Product data sheet Automation technology - sensors and actuators Product description M12-A female cable connector, Contacts: 4, 4.0 - 6.0 mm, shieldable, screw clamp, IP67, UL Area Order number M12-A series 713 99 1430 814 04 Illustration Scale drawing Contact arrangement You can find the component part drawing and assembly instructions on the next page. Technical data General values Connector design Connector locking system Termination Wire gauge (mm) Wire gauge (AWG) Cable outlet Upper limit temperature Lower limit temperature Customs tariff number Packaging Unit Electrical values female cable connector screw screw clamp 0.75 mm² 18 4.0 - 6.0 mm 85 °C – 40 °C 85369010 50 Cable data Approval 1 Rated current (40 °C) Rated voltage Rated impulse voltage Pollution degree Overvoltage category Insulating material group Insulation resistance EMC compliance Degree of protection Mechanical operation 4 A (3 A UL) 250 V 2500 V 3 II III > 10⁸ Ω shieldable IP67 > 100 Mating cycles Material UL Contact material Contact plating Contact body material Housing material CuZn (brass) Au (gold) PA Zinc die-cast nickel-plated Date: 2020-01-19 - Page 1 of 3 Product data sheet Automation technology - sensors and actuators Product description M12-A female cable connector, Contacts: 4, 4.0 - 6.0 mm, shieldable, screw clamp, IP67, UL Area Order number M12-A series 713 99 1430 814 04 Component part drawing Assembly instructions / Panel cut-out Date: 2020-01-19 - Page 2 of 3 Powered by TCPDF (www.tcpdf.org) Product data sheet Automation technology - sensors and actuators Product description M12-A female cable connector, Contacts: 4, 4.0 - 6.0 mm, shieldable, screw clamp, IP67, UL Area Order number M12-A series 713 99 1430 814 04 Security notices The connector must not be connected or separated under load. Non-observance and incorrect use can result in personal injury. The connectors are designed for use in plant, control system and electrical equipment. The end user is responsible for checking whether the connectors are suitable for use in other applications. To prevent the connector being opened unintentionally when used in electrical circuits containing hazardous life parts, the thread between the housing and the connector head must be secured using a suitable cyanoacrylate adhesive. This does not apply to connectors used in SELV and PELV circuits according to IEC 61140 (EN 61140, VDE 0140-1). Connectors used in electrical circuits containing hazardous life parts must only be assembled and used by or under the supervision of persons with the requisite electrotechnical training, taking the applicable regulations and standards into account. Connectors with degree of protection IP 67 and IP 68 are not suitable for use under water. When used outdoors, the connectors must be separately protected against corrosion. For further information about IP degrees of protection refer to ‘Technical support’ in the Download Centre. To lock the cable connector to the equipment connector, the threaded ring is tightened until it is ‘finger-tight’ (approx. 50 cNm). Date: 2020-01-19 - Page 3 of 3
99-1430-814-04 价格&库存
很抱歉,暂时无法提供与“99-1430-814-04”相匹配的价格&库存,您可以联系我们找货
  • 1+194.30138
  • 10+191.35426
  • 50+187.98018
  • 100+183.17940
  • 250+178.37862
库存:123
