99-3787-810-08
99-3787-810-08
    BINDER(宾德)
    BINDER - 99-3787-810-08 - Sensor Connector, X-Coded, CAT6A, 825 Series, M12, Male, 8 Positions, IDC ...
99-3787-810-08 数据手册
Product sheet Automation technology - Speciality connectors Product cable outlet: 5.5 - 9 mm, Contacts: 8, Cable plug connector with X-coding, shieldable, CAT 6A, insulation displacement connection Area Article number M12-D, M12-X Series 825 X-coding 99 3787 810 08 Illustration Scale drawing Contact Arrangement You can find the item description and assembly instruction on the next page. Technical data Common values Connector Design Connector locking system Termination Wire gauge (AWG) Cable outlet Upper temperature Lower temperature Electrical values Cable plug connector screw Screw terminal 27 - 22 5.5 - 9 mm 85 °C -40 °C Rated voltage Rated impulse voltage Pollution degree Overvoltage category Material group Rated current (40°C) Volume resistivity Degree of protection Mechanical operation - Material Cable data material housing Insulation single lead Single lead structure Conductor resistance Bending radius cable fixed Bending radius cable movable Material of contact Contact plating Material of contact body Material of housing 50 V AC / 60 V DC 800 V 3 II II 0.5 A ≤ 10 mΩ IP67 > 100 mating cycles CuZn (Brass) Au (Gold) PA Nickel-plated brass / nickel-plated zinc die casting Date: 2016-01-13 - Page 1 of 2 Powered by TCPDF (www.tcpdf.org) Product sheet Automation technology - Speciality connectors Product cable outlet: 5.5 - 9 mm, Contacts: 8, Cable plug connector with X-coding, shieldable, CAT 6A, insulation displacement connection Area Article number M12-D, M12-X Series 825 X-coding 99 3787 810 08 Item description Installation instructions / Mounting cutout Date: 2016-01-13 - Page 2 of 2
99-3787-810-08 价格&库存
很抱歉,暂时无法提供与“99-3787-810-08”相匹配的价格&库存,您可以联系我们找货
    • 1+773.42527
    • 10+711.45252
    库存:1
