Product sheet
Miniature connectors
Female cable connector, cable outlet 3-6 mm
M16 connectors IP 40
illustration
Pole
Article number
serie 680
scale drawing
Date: 2014-01-15 - Page 1 of 2
Product
Area
7
09 0326 00 07
Contact Arrangement
You can find the item description on the next page.
Technical data
Common values
Material
Connector Design
Connector locking system
Screw
Termination
solder
Wire gauge (mm)
0,75 mm²
Wire gauge (AWG)
Cable outlet
3 - 6 mm
Upper temperature
+85 °C
Lower temperature
-40 °C
Material of contact
CuSn (bronce)
Contact plating
Ag (silver)
Material of contact body
PBT (UL 94 V-0)
Material of housing
PA (UL 94 HB)
Cable data
Contacts 7, female cable connector, cable
outlet 3 – 6 mm, silver plated contacts
Electrical values
Rated voltage
125 V
Rated impulse voltage
800 V
Pollution degree
1
Overvoltage category
I
Material group
III
Rated current (40°C)
5A
Volume resistivity
≤ 5 mΩ
EMV compliance
not shielded
Degree of protection
IP 40
Mechanical operation
>500 mating cycles
Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de
09 0326 00 07
Product sheet
serie 680
Pole
Article number
Date: 2014-01-15 - Page 2 of 2
Product
Area
7
09 0326 00 07
Item description
Powered by TCPDF (www.tcpdf.org)
09 0326 00 07
很抱歉,暂时无法提供与“09 0326 00 07”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+106.751471+13.81990
- 5+95.578795+12.37350
- 20+85.0171120+11.00620
- 100+74.36815100+9.62760
