09 9789 71 05
09 9789 71 05
    BINDER(宾德)
    BINDER - 09 9789 71 05 - Circular Connector, 719 Series, Cable Mount Plug, 5 Contacts, Solder Pin, N...
09 9789 71 05 数据手册
Product sheet Subminiature connectors Male cable connector with strain relief Snap-in connectors IP 40 illustration Pole Article number serie 719 scale drawing Date: 2013-10-02 - Page 1 of 2 Product Area 5 09 9789 71 05 Contact Arrangement You can find the item description on the next page. Technical data Common values Material Connector Design Male cable connector Connector locking system Snap-in locking Termination solder Wire gauge (mm) 0,25 mm² Wire gauge (AWG) 24 Max. Cable outlet max. 5 mm Upper temperature +70 °C Lower temperature -25 °C Electrical values Rated voltage 60 V Rated impulse voltage 800 V Pollution degree 1 Overvoltage category II Material group III Rated current (40°C) 3A Volume resistivity ≤ 3 mΩ EMV compliance not shieldable Degree of protection IP 40 Mechanical operation >100 mating cycles Material of contact CuZn (brass) Contact plating Au (gold) Material of contact body PA Material of housing PA Cable data material housing - insulation single lead - single lead structure - conductor resistance - Contacts 5, Male cable connector with strain relief, max. cable-Ø 5 mm Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de 09 9789 71 05 Product sheet Subminiature connectors Male cable connector with strain relief Snap-in connectors IP 40 serie 719 Pole Article number Date: 2013-10-02 - Page 2 of 2 Product Area 5 09 9789 71 05 Item description Normen und Prüfbedingungen siehe Binder Katalog Seite T1-16 oder unter www.binder-connector.de Powered by TCPDF (www.tcpdf.org) 09 9789 71 05
09 9789 71 05 价格&库存
很抱歉,暂时无法提供与“09 9789 71 05”相匹配的价格&库存,您可以联系我们找货
