BZT55C9V1
BZT55C9V1
    MULTICOMP
BZT55C9V1 数据手册
BZT55C- Series Features: •  •  •  •  •  •  •  •  Zener voltage range 2 to 75 Volts. Mini-MELF package. Surface device type mounting. Hermetically sealed glass. Compression Bonded Construction. All external surfaces are corrosion resistant and terminals are readily solderable. Matte Tin (Sn) lead finish. Blue color band indicates negative polarity. Maximum Ratings and Electrical Characteristics Type Number Power Dissipation Operating and Storage Temperature Range Symbol Value Units Pd 500 mW Tj, Tstg -65 to + 200 °C Notes : These ratings are limiting values above which the serviceability of the diode may be impaired. Ratings and Characteristic Curves www.element14.com www.farnell.com www.newark.com Page 19/01/15 V1.1 BZT55C- Series www.element14.com www.farnell.com www.newark.com Page 19/01/15 V1.1 BZT55C- Series Electrical Characteristics (TA=25°C unless otherwise noted) Vz at Izt (Volts) Izt mA Zzt at Izt Ω Max. Izk mA Zzk at Izk Ω Ir at Vr μA Max. Vr V Vz Typical V Part Number 10.6 5 15 1 70 0.1 7.5 10 BZT55C10 10.4 11.6 5 20 1 70 0.1 8.2 11 BZT55C11 Vz Min. (V) Vz Max. (V) 9.4 11.4 12.7 5 20 1 90 0.1 9.1 12 BZT55C12 12.4 14.1 5 26 1 110 0.1 10 13 BZT55C13 13.8 15.6 5 30 1 110 0.1 11 15 BZT55C15 15.3 17.1 5 40 1 170 0.1 12 16 BZT55C16 16.8 19.1 5 50 1 170 0.1 13 18 BZT55C18 18.8 21.1 5 55 1 220 0.1 15 20 BZT55C20 20.8 23.3 5 55 1 220 0.1 16 22 BZT55C22 22.8 25.6 5 80 1 220 0.1 18 24 BZT55C24 25.1 28.9 2 80 1 220 0.1 20 27 BZT55C27 1.88 2.11 5 100 1 600 50 1 2 BZT55C2V0 2.08 2.33 5 100 1 600 50 1 2.2 BZT55C2V2 2.28 2.56 5 85 1 600 50 1 2.4 BZT55C2V4 2.51 2.89 5 85 1 600 10 1 2.7 BZT55C2V7 28 32 2 80 1 220 0.1 22 30 BZT55C30 31 35 2 80 1 220 0.1 24 33 BZT55C33 34 38 2 80 1 220 0.1 27 36 BZT55C36 37 41 2 90 0.5 500 0.1 28 39 BZT55C39 2.8 3.2 5 85 1 600 4 1 3 BZT55C3V0 3.1 3.5 5 85 1 600 2 1 3.3 BZT55C3V3 3.4 3.8 5 85 1 600 2 1 3.6 BZT55C3V6 www.element14.com www.farnell.com www.newark.com Page 19/01/15 V1.1 BZT55C- Series Vz at Izt (Volts) Izt mA Zzt at Izt Ω Max. Izk mA Zzk at Izk Ω Ir at Vr μA Max. Vr V Vz Typical V Part Number Vz Min. (V) Vz Max. (V) 3.7 4.1 5 85 1 600 2 1 3.9 BZT55C3V9 40 46 2 90 0.5 600 0.1 35 43 BZT55C43 44 50 2 110 0.5 700 0.1 35 47 BZT55C47 4.0 4.6 5 75 1 600 2 1 4.3 BZT55C4V3 4.4 5 5 60 1 600 0.5 1 4.7 BZT55C4V7 48 54 2 125 0.5 700 0.1 38 51 BZT55C51 52 60 2 135 0.5 1,000 0.1 42 56 BZT55C56 4.8 5.4 5 35 1 550 0.1 1 5.1 BZT55C5V1 5.2 6.0 5 25 1 450 0.1 1 5.6 BZT55C5V6 58 66 2.5 150 0.5 1,000 0.1 47 62 BZT55C62 64 72 2.5 160 0.5 1,000 0.1 51 68 BZT55C68 5.8 6.6 5 10 1 200 0.1 2 6.2 BZT55C6V2 6.4 7.2 5 8 1 150 0.1 3 6.8 BZT55C6V8 70 80 2.5 170 0.5 1,000 0.1 56 75 BZT55C75 7.0 7.9 5 7 1 50 0.1 5 7.5 BZT55C7V5 7.7 8.7 5 7 1 50 0.1 6.2 8.2 BZT55C8V2 8.5 9.6 5 10 1 50 0.1 6.8 9.1 BZT55C9V1 VF Forward Voltage = 1V Maximum at If = 100mA for all types. Notes : 1. The type numbers listed have zener voltage min/max limits as shown. 2. The zener impedance is derived from the 60-cycle AC voltage, which results when an AC current having an rams value equal to 10% of the dc zener current (Izt or Izk) is superimposed to Izt or Izk. Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Multicomp is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com Page 19/01/15 V1.1
BZT55C9V1 价格&库存
很抱歉,暂时无法提供与“BZT55C9V1”相匹配的价格&库存,您可以联系我们找货
