CP1006
CP1006
    MULTICOMP
CP1006 数据手册
Single Phase Bridge Rectifiers CP 10 A Series Features: • • • • • • High surge current capability PCB mounted / screw fixing Surge overload rating-200 amperes peak Low forward voltage drop and reverse leakage Small size, simple installation Reliable low cost construction utilizing moulded plastic technique Mechanical Data Case Terminals : Moulded plastic with heatsink integrally mounted in the bridge encapsulation : Lead solderable per MIL-STD-202 method 208 Dimensions : Inches (Millimetres) Maximum Ratings and Electrical Characteristics Ratings at 25°C ambient temperature unless otherwise noted; resistive or inductive load at 60 Hz Parameter CP1000 CP1001 CP1004 CP1006 CP1008 Units Maximum Recurrent Peak Reverse Voltage 50 100 400 600 800 Maximum Bridge Input Voltage RMS 35 70 280 420 560 V Maximum Average Rectified Output at TA = 50°C* See Figure 2 10 Peak One Cycle Surge Overload Current 200 Maximum Forward Voltage Drop Per Element at 5 A dc and 25°C See Figure 3 1.1 V Maximum Reverse Leakage at Rated DC Blocking Voltage Per Element at 25°C See Figure 4 at 100°C 10 1 µA mA Typical Junction Capacitance Per leg (Note 4) CJ 200 pF I2t Rating for Fusing (t
CP1006 价格&库存
很抱歉,暂时无法提供与“CP1006”相匹配的价格&库存,您可以联系我们找货
