1.5KE47CA+
1.5KE47CA+
    MULTICOMP
    MULTICOMP - 1.5KE47CA+ - TVS DIODE, 1.5KW, 40.2V, BIDIR, DO-201AE
1.5KE47CA+ 数据手册
Transient Voltage Suppressors Dimensions: Features: •  •  •  •  •  •  •  •  •  •  •  •  Glass passivated chip junction in moulded plastic package 1,500W surge capability at 1ms Low zener impedance Excellent clamping capability Fast response time: Typically less than 1 ps from 0 volts to BV minimum Typical IR less than 1µA above 10V High temperature soldering: 260°C / 10 seconds /.375 inches, (9.5mm) lead length / 5 lbs. (2.3 kg) tension Low clamping voltage Wide voltage range High transient power dissipation No wear-out limitation Small physical size Dimensions : Inches (Millimetres) Mechanical Data Case Terminals Polarity Mounting Position Weight : JEDEC DO-201AE moulded plastic : Axial leads, solderable per MIL-STD-202, Method 208 : Colour band denotes cathode except in Bi-Directional : Any : 0.045 ounce, 1.2 g Maximum Ratings and Electrical Characteristics Ratings at 25°C ambient temperature unless otherwise specified Symbol Value 1.5KE Series Peak Power Dissipation at Ta = 25°C , TP = 1 ms (Note 1) Ppk Minimum 1,500 Steady State Power Dissipation at Tl = 75°C Lead Lengths 5.8 to 7.6, 7.2 to 9.5 (Note 2) Pd 5 Peak Forward Surge Current, 8.3 ms Single Half Sine-Wave Superimposed on Rated Load (JECED Method) (Note 3) Ifsm 200 Ampere Tj,Tstg -65 to +175 °C Ratings Operating and Storage Temperature Range Units Watt Notes 1. Non-repetitive current pulse, per Fig. 3 and derated above Ta = 25°C per Fig. 2 2. Mounted on copper Leaf area of 0.79in2 (20mm2) 3. 8.3 ms single half sine-wave, duty cycle = 4 pulses per minutes maximum Newark.com/multicomp-pro Farnell.com/multicomp-pro Element14.com/multicomp-pro Page 11/09/19 V1.1 Transient Voltage Suppressors Rating and Characteristic Curves Newark.com/multicomp-pro Farnell.com/multicomp-pro Element14.com/multicomp-pro Page 11/09/19 V1.1 Transient Voltage Suppressors Uni-Directional 1,500 Watt Axial Lead TVS Stand-off Voltage Vrm (V) 5.5 Breakdown Voltage Vbr (V) Minimum Breakdown Voltage Vbr (V) Maximum Itest (mA) 6.45 7.14 10 13.6 15.2 16.8 22.5 67 1.5KE16A+ 15.3 17.1 18.9 25.2 59.5 1.5KE18A+ 23.1 25.7 28.4 37.5 40 1.5KE27A+ 25.6 28.5 31.5 41.4 36 30.8 34.2 37.8 49.9 30 40.2 44.7 49.4 64.8 23.2 1.5KE47A+ 136 152 162 219 6.8 1.5KE160A+ 342 380 420 548 4 1.5KE400A+ Clamping Voltage Vclamp A 10.5 Maximum Peak Pulse Current Ipp (A) 143 1 Clamping Voltage Vclamp A 10.5 Maximum Peak Pulse Current Ipp (A) 143 Ptot at Tl = 75°C (W) Uni-Directional Part Number 1.5KE6.8A+ 5 1.5KE30A+ 1.5KE36A+ Bi-Directional 1,500 Watt Axial Lead TVS Stand-off Voltage Vrm (V) 5.8 Breakdown Voltage Vbr (V) Minimum Breakdown Voltage Vbr (V) Maximum Itest (mA) 6.45 7.14 10 13.6 15.2 16.8 22.5 67 1.5KE16CA+ 15.3 17.1 18.9 25.2 59.5 1.5KE18CA+ 23.1 25.7 28.4 37.5 40 1.5KE27CA+ 25.6 28.5 31.5 41.4 36 28.2 31.4 34.7 45.7 33 30.8 34.2 37.8 49.9 30 40.2 44.7 49.4 64.8 23.2 1.5KE47CA+ 136 152 168 219 6.8 1.5KE160CA+ 342 380 420 548 4 1.5KE400CA+ 1 Ptot at Tl = 75°C (W) Bi-Directional Part Number 1.5KE6.8CA+ 5 1.5KE30CA+ 1.5KE33CA+ 1.5KE36CA+ Important Notice : This data sheet and its contents (the “Information”) belong to the members of the AVNET group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Multicomp Pro is the registered trademark of Premier Farnell Limited 2019. Newark.com/multicomp-pro Farnell.com/multicomp-pro Element14.com/multicomp-pro Page 11/09/19 V1.1
1.5KE47CA+ 价格&库存
很抱歉,暂时无法提供与“1.5KE47CA+”相匹配的价格&库存,您可以联系我们找货
