1N4758A
1N4758A
    MULTICOMP
1N4758A 数据手册
1N47- Series Features: • • • • • • Low profile package. Built-in strain relief. Glass passivated junction. Low inductance. Typical IR less than 5.0µA above 11V. High temperature soldering guaranteed: 260°C/10 seconds at terminals • Plastic package has underwriters laboratory flammability classification 94V-0 DO-41 Dimensions : Inches (Millimetres) Mechanical Data Case Lead Polarity Mounting position Weight : Moulded plastic DO-41. : Pure tin plated lead free, solderable per MIL-STD-202, Method 2025. : Color band denotes cathode end. : Any. : 0.012 ounces, 0.3 gram. Page 18/07/08 V1.1 1N47- Series Maximum Ratings and Electrical Characteristics Rating at 25°C Ambient Temperature Unless Otherwise Specified. Type Number Peak Power Dissipation at TA = 50°C, Derate above 50°C (Note 1) Peak Forward Surge Current, 8.3ms Single Half Sine-wave Superimposed on Rated Load (JEDEC method) (Note 2) Operating and Storage Temperature Range Symbol Value Units PD 1.0 6.67 Watts mW/°C IFSM 10.0 Amps TJ, TSTG -55 to +150 °C Notes : 1. Mounted on 5.0mm2 (0.013mm thick) land areas. 2. Measured on 8.3ms single half sine-wave or equivalent square wave, duty cycle = 4 pulses per minute maximum. Electrical Characteristics (TA = 25°C Unless Otherwise Noted) VF = 1.2V maximum, IF = 200mA for all types. Zener Voltage VZ at IZT Voltage Power (Watt) Test Current IZT mA Nom. (Notes 2 & 3) Minimum Maximum Maximum Zener Impedance (Note 4) ZZT at IZT Ohms 12 11.40 12.60 21 9 13 12.35 13.65 19 10 ZZK at IZK Ohms mA Leakage Current IR @ VR uA Maximum Volts Surge Current at Part Number TA = 25°C Ir = mA (Note 5) 9.1 380 1N4742A 9.9 344 1N4743A 700 15 14.25 15.75 17 14 11.4 3.4 1N4744A 16 15.20 16.80 15.5 16 12.2 285 1N4745A 18 17.10 18.90 14.0 20 13.7 250 1N4746A 20 19.00 21.00 12.5 22 15.2 225 1N4747A 22 20.90 23.10 11.5 23 16.7 205 1N4748A 24 22.80 25.20 10.5 25 18.2 190 1N4749A 27 25.65 28.35 9.5 35 20.6 170 1N4750A 22.8 150 1N4751A 25.1 135 1N4752A 27.4 125 1N4753A 35.8 95 1N4756A 750 1 0.25 30 28.50 31.50 8.5 40 33 31.35 34.65 7.5 45 36 34.20 37.80 7.0 50 47 44.65 49.35 5.5 80 1000 5.0 1500 51 48.45 53.55 5.0 95 38.8 90 1N4757A 56 53.20 58.80 4.5 110 42.6 80 1N4758A 68 64.60 71.40 3.7 150 51.7 65 1N4760A 75 71.25 78.75 3.3 175 56.0 60 1N4761A 100 95.00 105.0 2.5 350 76.0 45 1N4764A 2000 3000 Page 18/07/08 V1.1 1N47- Series Notes 1: Tolerance and Type Number Designation. The type numbers listed have a standard tolerance on the nominal zener voltage of ±5%. 2. Specials Available Include: A. Nominal zener voltages between the voltages shown and tighter voltage tolerances. B. Matched sets. 3. Zener Voltage (VZ) Measurement. Guarantees the zener voltage when messured at 90 seconds while maintaining the lead temperature (TL) at 30oC± 1oC, from the diode body. 4. Zener Impedance (ZZ) Derivation. The zener impedance is derived from the 60 cycle ac voltage, which results when an accurrent having and rms value equal to 10% of the dc zener current (IZT or IZK) is superimposed on IZT or IZK. 5. Surge Current (Ir) Non-Repetitive. The rating listed in the electrical characteristics table is maximum peak, non-repetitive, reverse surge current of 1/2 square wave or equivalent sine wave pulse of 1/120 second duration superimposed on the test current, IZT, per JEDEC registration; however, actual device capability is as described. Ratings and Characteristics Curves ( 1N4742A thru 1N4753A, 1N4756A thru 1N4758A, 1N4760A, 1N4761A and 1N4764A Typical Forward Characteristics IF - Forward Current (mA) PD, Maximum Pwer Dissipation (watts) Power Temperature Derating Curve Ambient Temperature (°C) VF - Forward Voltage (Volts) Effect of Zener Voltage on Zener Impedance ZZ - Dynamic Impedance (Ohms) ZZ - Dynamic Impedance (Ohms) Effect of Zener Current on Zener Impedance IZ - Zener Current (mA) IZ - Zener Current (mA) Page 18/07/08 V1.1 1N47- Series Typical Capacitance verses Vz IR, Leakage Current (µA) C - Capacitance (pF) Typical Leakage Current VZ - Forward Voltage (Volts) VZ, Nominal Zener Voltage (Volts) Temperature Coefficients b - Range for Units to 12 to 100 Volts θVZ , Temperature Coefficient (mV/°C) θVZ , Temperature Coefficient (mV/°C) Temperature Coefficients a - Range for Units to 12 Volts VZ , Zener Voltage (Volts) VZ , Zener Voltage (Volts) Page 18/07/08 V1.1 1N47- Series Typical Thermal Resistance versus Lead Length θJL, Junction to Lead Thermal Resistance (°C/W) θVZ , Temperature Coefficient (mV/°C) Effect of Zener Current L, Lead Length to Heat Sink (Inches) VZ , Zener Voltage (Volts) PPk, Peak Surge Power Iwattso Maximum Surge Power PW, Pulse Width (mS) Page 18/07/08 V1.1 1N47- Series Notes: International Sales Offices: AUSTRALIA – Farnell FINLAND – Farnell ITALY – Farnell SPAIN – Farnell Tel No: Tel No: Tel No: Tel No: ++61 1300 361 005 ++ 358 9 560 7780 ++ 39 02 93 995 200 901 20 20 80 Fax No: ++61 1300 361 225 Fax No: ++ 358 9 345 5411 Fax No: ++ 39 02 93 995 300 Fax No: 901 20 20 90 AUSTRIA – Farnell FRANCE – Farnell SWEDEN – Farnell Tel No: Tel No: Fax No: ++ 43 662 2180 670 Fax No: ++ 33 474 68 99 90 MALAYSIA – Farnell-Newark Tel No: ++ 60 3 7873 8000 Fax No: ++ 60 3 7873 7000 BELGIUM – Farnell GERMANY – Farnell NETHERLANDS – Farnell SWITZERLAND – Farnell Tel No: Tel No: Tel No: ++ 43 662 2180 680 ++ 33 474 68 99 99 Tel No: ++ 46 8 730 50 00 Fax No: ++ 46 8 83 52 62 Fax No: ++ 32 3 227 3648 Fax No: ++ 49 89 613 59 01 Fax No: ++ 31 30 241 7333 Tel No: ++ 44 204 64 64 Fax No: ++ 44 204 64 54 BRAZIL – Farnell-Newark HONG KONG – NEW ZEALAND – Farnell UK – Farnell Tel No: Tel No: ++ 32 3 475 2810 ++ 49 89 61 39 39 39 ++ 31 30 241 7373 ++ 55 11 4066 9400 Farnell-Newark Tel No: ++ 852 2268 9888 Fax No: ++ 55 11 4066 9410 Fax No: ++ 852 2268 9899 Fax No: 0800 90 80 81 Fax No: ++ 44 8701 200 201 CHINA – Farnell-Newark HUNGARY - Farnell NORWAY – Farnell UK – CPC Tel No: Tel No: Tel No: 800 146 70 ++ 44 8701 202 530 Tel No: ++86 10 6238 5152 ++ 44 870 1200 208 0800 90 80 80 ++ 44 8701 200 200 Fax No: ++86 10 6238 5022 Fax No: ++ 44 870 1200 209 Fax No: 800 146 76 ++ 44 8701 202 531 CZECH REPUBLIC - Farnell INDIA - Farnell PORTUGAL – Farnell USA – Tel No: Tel No: Tel No: ++ 44 870 1200 208 ++ 44 870 1200 208 Fax No: ++ 44 870 1200 209 Fax No: ++ 44 870 1200 209 Fax No: ++ 34 93 474 5288 DENMARK – Farnell IRELAND – Farnell RUSSIA – Farnell Tel No: Tel No: Tel No: ++ 45 44 53 66 44 Fax No: ++ 45 44 53 66 06 ++ 353 1 830 9277 ++ 44 870 1200 208 Fax No: ++ 44 870 1200 209 Fax No: ++ 353 1 830 9016 Newark ++ 34 93 475 8804 Tel No: export 800 463 9275 EXPORT – Farnell Tel No: ++ 44 8701 200 208 Fax No: ++ 44 8701 200 209 For enquiries from all other markets ESTONIA – Farnell ISRAEL – Farnell Tel No: Tel No: ++ 358 9 560 7780 Fax No: ++ 358 9 345 5411 SINGAPORE – Farnell-Newark Tel No: ++ 65 6788 0200 ++ 180 937 0015 Fax No: ++ 180 937 0014 Fax No: ++ 65 6788 0300 http://www.farnell.com http://www.newark.com http://www.cpc.co.uk Disclaimer This data sheet and its contents (the "Information") belong to the Premier Farnell Group (the "Group") or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group's liability for death or personal injury resulting from its negligence. SPC Multicomp is the registered trademark of the Group. © Premier Farnell plc 2008. Page 18/07/08 V1.1
1N4758A 价格&库存
很抱歉,暂时无法提供与“1N4758A”相匹配的价格&库存,您可以联系我们找货
1N4758A
  • 1+0.35714
库存:3580
