1SMA4741 THRU 1SMA4764
Surface Mount Silicon Zener Diode
Voltage Range
11 to 200 Volts
1.0 Watts Peak Power
SMA/DO-214AC
Features
a For surface mounted applications in order to optimize
board space
a Low profile package
a Built-in strain relief
a Glass passivated junction
a Low inductance
a Typical IR less than 5.0A above 11V
a High temperature soldering guaranteed:
O
260 C / 10 seconds at terminals
a Plastic package has Underwriters Laboratory
Flammability Classification 94V-0
Mechanical Data
.062(1.58)
.056(1.43)
.111(2.83)
.102(2.58)
.187(4.75)
.167(4.25)
.103(2.61)
.078(1.99)
.012(.31)
.006(.15)
.008(.20)
.004(.10)
a Case: Molded plastic over passivated junction
a Terminals: Solder plated solderable per
MIL-STD-750, Method 2025
a Polarity:Color Band denotes positive end (cathode)
a Standard packaging: 12mm tape (EIA-481)
.056(1.41)
.035(0.90)
.210(5.33)
.195(4.95)
Dimensions in inches and (millimeters)
aWeight: 0.002 ounces, 0.064 gram
Maximum Ratings and Electrical Characteristics
Rating at 25ambient temperature unless otherwise specified.
Type Number
Peak Power Dissipation at TA=50OC,
Derate above 50 OC (Note 1)
Peak Forward Surge Current, 8.3 ms Single Half
Sine-wave Superimposed on Rated Load
(JEDEC method) (Note 2)
Operating and Storage Temperature Range
Symbol
PD
Value
1.0
6.67
Units
Watts
mW/ OC
IFSM
10.0
Amps
TJ, TSTG
-55 to + 150
Notes: 1. Mounted on 5.0mm (0.013mm thick) land areas.
2. Measured on 8.3ms Single Half Sine-wave or Equivalent Square Wave,
Duty Cycle=4 Pulses Per Minute Maximum.
2
O
C
E LE C TR IC A L C H A R A C TE R IS TIC S (TA =25 O C unless otherw ise noted) V F=1.2V m ax, IF=200m A for all types.
Device
(Note 1)
1SM A4741
1SM A4742
1SM A4743
1SM A4744
1SM A4745
1SM A4746
1SM A4747
1SM A4748
1SM A4749
1SM A4750
1SM A4751
1SM A4752
1SM A4753
1SM A4754
1SM A4755
1SM A4756
1SM A4757
1SM A4758
1SM A4759
1SM A4760
1SM A4761
1SM A4762
1SM A4763
1SM A4764
Device
M arking
Code
Nom inal
Zener Voltage
Vz @ Izt
Voltage
(Notes 2 & 3)
741A
742A
743A
744A
745A
746A
747A
748A
749A
750A
751A
752A
753A
754A
755A
756A
757A
758A
759A
760A
761A
762A
763A
764A
11
12
13
15
16
18
24
27
30
33
36
39
43
47
51
56
62
68
75
82
91
100
Test
Current M axim um Zener Im pedance (Note 4) Leakage Current
ZZK @ IZK
IR @ VR
IZT
ZZT @ IZT
mA
Ohm s
Ohm s
mA
uA Max
Volts
23
21
19
17
15.5
14.0
12.5
11.5
10.5
9.5
8.5
7.5
7.0
6.5
6.0
5.5
5.0
4.5
4.0
3.7
3.3
3.0
2.8
2.5
8
9
10
14
16
23
25
35
40
45
50
60
70
80
95
110
125
150
175
200
250
350
700
700
700
700
700
750
750
750
750
750
1000
1000
1000
1000
1500
1500
1500
2000
2000
2000
2000
3000
3000
3000
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
Surge Current @
O
TA = 25 C
Ir - m A
(Note 5)
8.4
9.1
9.9
11.4
12.2
13.7
15.2
16.7
18.2
20.6
22.8
25.1
27.4
29.7
32.7
35.8
38.8
42.6
47.1
51.7
56.0
62.2
69.2
76.0
414
380
344
304
285
250
225
205
190
170
150
135
125
115
110
95
90
80
70
65
60
55
50
45
Notes:
1. Tolerance and Type Num ber Designation. The type num bers listed have a standard tolerance on the nom inal zener voltage of ±5% .
2. Specials Available Include:
A. Nom inal zener voltages between the voltages shown and tighter voltage tolerances.
B. M atched sets.
3. Zener Voltage (V Z ) M easurem ent. Guarantees the zener voltage when m essured at 90 seconds while m aintaining
O
O
the lead tem perature (T L ) at 30 C± 1 C, from the diode body.
4. Zener Im pedance (ZZ) Derivation. The zener im pedance is derived from the 1000 cycle ac voltage, which results when an ac
current having and rm s value equal to 10% of the dc zener current (IZT or IZK) is superim posed on IZT or IZK.
5. Surge Current (Ir) Non-Repetitive. The rating listed in the electrical characteristics table is m axim um peak, non-repetitive,
reverse surge current of 1/2 square wave or equivalent sine wave pulse of 1/120 second duration superim posed on the
test current, IZT, per JEDEC registration; however, actual device capability is as described in Figure 10.
RATINGS AND CHARACTERISTIC CURVES ( 1SMA4741 THRU 1SMA4764)
FIG.2- TYPICAL FORWARD CHARACTERISTICS
1000
1.25
MINIMUM
MAXIMUM
500
IF, FORWARD CURRENT (mA)
PD, MAXIMUM POWER DISSIPATION (WATTS)
FIG.1- POWER TEMPERATURE DERATING CURVE
1.0
0.75
0.50
0.25
200
100
50
o
70 C
o
150 C
2.0
60
80
100
120
140
160
180
o
0 C
1.0
0.4
200
0.5
o
AMBIENT TEMPERATURE( C)
10000
7000
5000
100
27V
1.0
1.1
200
0.8V
10
0.9
1000
700
500
50
TYPICAL LEAKAGE CURRENT
AT 80% OF NOMINAL
BREAKDOWN VOLTAGE
2000
47V
100
70
50
5.0
2.0
1.0
0.1
0.2
0.5
1.0
2.0
5.0
10
100
IZ, ZENER CURRENT (mA)
FIG.4- EFFECT OF ZENER VOLTAGE
ON ZENER IMPEDANCE
1000
700
500
IR, LEAKAGE CURRENT ( A)
ZZ, DYNAMIC IMPEDANCE (OHMS)
o
TJ = 25 C
IZ(rms)= 0.1 IZ(dc)
f = 1KHz
200
0.7
FIG.5- TYPICAL LEAKAGE CURRENT
1000
500
0.6
VF, FORWARD VOLTAGE (VOLTS)
FIG.3- EFFECT OF ZENER CURRENT
ON ZENER IMPEDANCE
o
25 C
5.0
7.0
5.0
2.0
1.0
0.7
0.5
o
+125 C
0.2
o
TJ = 25 C
IZ(rms)= 0.1 IZ(dc)
f = 1KHz
IZ = 1.0mA
200
100
70
50
5.0mA
20mA
0.1
0.07
0.05
0.02
o
0.01
0.007
0.005
10
7.0
5.0
+25 C
0.002
2.0
0.001
3.0
1.0
1.0
2.0
3.0
5.0 7.0
10
30
50 70 100
4.0
5.0 6.0
7.0
8.0
9.0
10
11
12
VZ, NOMINAL ZENER VOLTAGE (VOLTS)
13
14
15
FIG.6- TYPICAL CAPACITANCE versus Vz
FIG.7- TEMPERATURE COEFFICIENTS
400
300
C, CAPACITANCE (pF)
0V BIAS
1.0V BIAS
100
10
8
50% OF BREAKDOWN BIAS
4
1.0
10
100
OVZ, TEMPERAYURE COEFFICIENT (mV/oC)
a-RANGE FOR UNITS TO 12 VOLTS
200
VZ, FORWARD VOLTAGE (VOLTS)
+12
+10
+8.0
+6.0
+4.0
+2.0
VZ @ IZT
RANGE
-4.0
2.0
3.0
4.0
5.0
6.0
7.0
8.0
9.0
10
11
12
VZ, ZENER VOLTAGE (VOLTS)
FIG.8- EFFECT OF ZENER CURRENT
b-RANGE FOR UNITS 11 TO 100 VOLTS
100
70
50
30
RANGE
10
VZ @ IZT
7.0
5.0
3.0
2.0
1.0
10
50
70
100
+6.0
VZ @ IZT
TA25 oC
+4.0
+2.0
20mA
0.01mA
1.0mA
-2.0
-4.0
NOTE: BELOW 3 VOLTS AND ABOVE a VOLTS
CHANGES IN ZENER CURRENT OO NOT
AFFECT TEMPERATURE COEFFICIENTS
3.0
4.0
5.0
6.0
7.0
8.0
Ppk, PEAK SURGE POWER IWATTSO
FIG.9- MAXIMUM SURGE POWER
100
70
50
30
RECTANGULAR
WAVEFORM
o
TJ = 25 C PRIOR TO
INITIAL PULSE
11V-91V NON-REPETITIVE
5% DUTY CYCLE
0.8V-10V NON-REPETITIVE
10% DUTY CYCLE
7.0
5.0
20% DUTY CYCLE
3.0
2.0
1.0
0.01
0.02
0.05
0.1
0.2
0.5
1.0
2.0
5.0
10
100
200
500
1000
PW, PULSE WIDTH (ms)
FIG.10- BREAKDOWN CHARACTERISTICS
TJ= CONSTANT (PULSED)
741A
mA
60
744A
746A
748A
TJ=25A
50
750A
IZ
40
752A
TEST CURRENT IZ
25mA
754A
30
756A
10mA
10
15
30
35
40
45
50V
VZ
FIG.11- BREAKDOWN CHARACTERISTICS
mA
758A
TJ=25A
760A
IZ
TEST CURRENT IZ
762A
10mA
764A
10
5mA
100
150
200V
VZ
Rev. 1 03/2003
很抱歉,暂时无法提供与“1SMA4749”相匹配的价格&库存,您可以联系我们找货
