507-1070
507-1070
    MULTICOMP
507-1070 数据手册
Solder Wires 60 / 40 Alloy Rosin Flux Features: • • • • • • Good wetting on most common surfaces Two activity levels: Multicomp 362 for general work and Multicomp 366 for more difficult surfaces Non-corrosive Fast soldering Rosin based Halide activated Product Range Multicomp 362 and 366 cored wires are manufactured with a range of flux contents. Although users will normally be using products with a nominal flux content of 3% Multicomp 362 and 366 cored wires are available in a variety of alloys conforming to J-STD-006 and EN 29453 or alloys conforming to similar national or international standards. For details refer to document “Properties of Alloys used in Cored Solder Wires”. A wide range of wire diameters is available Alternative flux contents and alloys may be manufactured to special order Technical Specification A full description of test methods and detailed test results are available on request Alloys The alloys used for Multicomp flux cored solder wires conform to the purity requirements of the common national and international standards. A wide range of wire diameters is available manufactured to close dimensional tolerances Flux Multicomp 362 and 366 solid flux leave dry and non-sticky residues. In use its odour is typically that of rosin fluxes Typical Flux Properties Test 362 366 Acid Value 170 mgKOH / g 158 mgKOH / g Halide Content
507-1070 价格&库存
很抱歉,暂时无法提供与“507-1070”相匹配的价格&库存,您可以联系我们找货
