CH291-1220LF
CH291-1220LF
    MULTICOMP
    CH291-1220LF
CH291-1220LF 数据手册
REVISIONS PART NO. CH291-1220LF ECN # REV DESCRIPTION DRAWN DATE CHECKD DATE - A RELEASED Asha 26/11/11 Veena 26/11/11 APPRVD DATE 10/12/11 Section : A-A PCB Mounting Layout Dimensions : Millimetres Specifications: General Tolerance Material: Housing Contact Maximum contact resistance Minimum insulation resistance Dielectric voltage Operating temperature : PPS : Phosphor bronze 0.2 thick Gold plated over nickel : 30 mΩ : 1,000 MΩ : 500 V one sec level : -55°C to 105°C Dimension : 0 ±0.3 0 ±0.2 Angle : ±3° 0 ±0.1 Part Number Table Description Part Number Battery Holder, SMT, 12 mm CH291-1220LF www.element14.com www.farnell.com www.newark.com Important Notice : This data sheet and its contents (the "Information") belong to the members of the Premier Farnell group of companies (the "Group") or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group's liability for death or personal injury resulting from its negligence. Multicomp is the registered trademark of the Group. © Premier Farnell plc 2011. TOLERANCES: UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE FOR REFERENCE PURPOSES ONLY. DRAWN BY: Asha CHECKED BY: DATE: 26/11/11 DATE: Veena 26/11/11 APPROVED BY: DATE: 10/12/11 DRAWING TITLE: Battery Holder SIZE A DWG NO. SCALE: NTS M10002772 U.O.M.: mm REV ELECTRONIC FILE CH 291-1220LF_DWG SHEET: 1 OF A 1
CH291-1220LF 价格&库存
很抱歉,暂时无法提供与“CH291-1220LF”相匹配的价格&库存,您可以联系我们找货
CH291-1220LF
  • 1+20.32475
  • 50+12.98031
  • 100+10.08525
  • 250+9.08859
  • 500+8.70891
  • 1500+8.13939
库存:12795
