CLS-TV-1010
CLS-TV-1010
    MULTICOMP
CLS-TV-1010 数据手册
Locking Fork Vinyl Insulated, Butted Seam Specifications: Barrel Seam Max. Voltage Rating : Butted : 600V Building Wire 1,000V Signs, Fixtures and Luminaires : 221°F (105°C) : Same as Wire : Vinyl : ETP Copper : Tin Max. Temperature Rating Max. Current Insulator Material Terminal Material Plating W C L E Stud Size Max. Lock Width W 6 0.27 0.25 8 0.34 0.30 CLS-TV-1810 10 0.35 0.32 CLS-TV-1406 6 0.27 0.25 8 0.34 0.30 CLS-TV-1410 10 0.35 0.32 CLS-TV-1006 6 0.30 0.28 8 0.35 10 0.36 1/4 0.48 Part Number Wire Range (AWG) CLS-TV-1806 CLS-TV-1808 CLS-TV-1408 CLS-TV-1008 CLS-TV-1010 22-18 16-14 12-10 CLS-TV-1025 0.32 0.43 C 0.25 L 0.88 E 0.7 Thickness Barrel Length 0.44 1.03 1.24 0.83 Max. Insulation Diameter 0.07 0.145 0.03 0.25 0.28 Barrel I.D. 0.04 0.09 0.135 0.17 0.25 0.99 Dimensions : Inches www.element14.com www.farnell.com www.newark.com Page 24/10/13 V1.0 Locking Fork Vinyl Insulated, Butted Seam Engineering Specification: Crimp-type terminals shall, electrically and mechanically, connect to a pre-stripped end of a stranded copper wire and have a flat tongue portion with a central opening for mounting around a screw or stud. The terminal line shall offer tongue variations in hole (stud) size (6, 8 10, etc.) and configuration (ring, fork, block fork, flanged block fork, locking fork, etc.) and barrel variations in wire (AWG) size (22-18, 16-14, 12-10, etc.) and construction (non-insulated brazed seam, vinyl insulated butted seam, nylon insulated with insulation grip, etc.). The terminal tongue shall be marked with the wire range and manufacturer’s symbol ( ). The vinyl-insulated, butted seam locking fork terminal shall be tin-plated, annealed copper, with the tongue having a specified stud slot (size 4 thru 1/4 in.) and a butted seam barrel covered by a molded vinyl funnel entry sleeve, colour coded and sized, for a specified (AWG) wire range (22-18, 16-14, 12-10). Part Number Table Description Part Number CLS-TV-1806 CLS-TV-1808 CLS-TV-1810 CLS-TV-1406 Locking Fork, Vinyl Insulated, Butted Seam CLS-TV-1408 CLS-TV-1410 CLS-TV-1006 CLS-TV-1008 CLS-TV-1010 CLS-TV-1025 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Multicomp is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com Page 24/10/13 V1.0
CLS-TV-1010 价格&库存
很抱歉,暂时无法提供与“CLS-TV-1010”相匹配的价格&库存,您可以联系我们找货
