CMA1-S-DC12V-A
CMA1-S-DC12V-A
    MULTICOMP
    MULTICOMP - CMA1-S-DC12V-A - SPST 12 Volt Relay
CMA1-S-DC12V-A 数据手册
1.COIL DATA Nominal Voltage Nominal Power Consumption 12VDC 800 mW 2.CONTACT DATA 2-1.Contact Arrangement 2-2.Contact Material 1 Form C , 1 Form A AgSnO2 15A 16VDC Resistive ( 1 Form C ) 20A 16VDC Resistive ( 1 Form A ) 75 VDC 20A 160W ( 1 Form C ) 320W ( 1 Form A ) 2-3.Contact Rating 2-4.Max. Switching Voltage 2-5.Max. Switching Current 2-6.Max. Switching Power Load 2-7.Max. Load Current ( 14VDC Load Voltage ) 2-8.Contact Resistance ( Initial ) 2-9.Life Expectancy Electrical Mechanical 26-531 (Form A) 3-2.Dielectric Strength 3-3.Operate Time 3-4.Release Time 3-5.Temperature Range 3-6.Shock Resistance 3-7.Vibration Resistance 3-8.Weight 3-9.Safety Standard NO NC Max.Carry Current 15A 15A 10A Max.Make Current 50A 50A 15A Max.Break Current 15A 15A 10A 50 mΩ at 6VDC 1A 100,000 operations at nominal load 200,000 operations at 14VDC resistive load 10,000,000 operations 3.GENERAL DATA 3-1.Insulation Resistance 26-532 (Form C) Min.100Ω¸ at 500 VDC 750VAC , 1min between open contacts 1,500VAC , 1min between contacts and coil Max. 10ms Max. 5ms -40 to +70 ¡æ 10G 10 - 55 Hz , Amplitude 1.5mm 12 gr. 4.DIMENSIONS ( in mm ) ¡¡ 6.COIL DATA CHART at 20¡æ ORDERING CODE CMA1-S DC12V COIL NOMINAL VDC COIL RESISTANCE +/- 10% OPERATE VOLTAGE VDC RELEASE VOLTAGE VDC COIL NOMINAL mW 12 180Ω 7.2 1.20 800 Table 1 7.CMA1 CHARACTERISTIC DATA
CMA1-S-DC12V-A 价格&库存
很抱歉,暂时无法提供与“CMA1-S-DC12V-A”相匹配的价格&库存,您可以联系我们找货
