CM25010
CM25010
    MULTICOMP
CM25010 数据手册
Single Phase Bridge Rectifiers CM2500 Series Features: • • Metal case for maximum heat dissipation Surge overload ratings to 400 amperes CM Series Dimensions : Inches (Millimetres) Mechanical Data Case Mounting Position : Metal : Any www.element14.com www.farnell.com www.newark.com Page 18/05/12 V1.1 Single Phase Bridge Rectifiers CM2500 Series Maximum Ratings and Electrical Characteristics Ratings at 25°C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load. For capacitive load, derate current by 20% Parameter CM2501 CM2502 CM2504 CM2506 CM2508 CM25010 Maximum Recurrent Peak Reverse Voltage 100 200 400 600 800 1,000 Maximum RMS Bridge Input Voltage 70 140 280 420 560 700 Maximum DC Blocking Voltage 100 200 400 600 800 1,000 Unit V Maximum Average Forward Current at TA = 55°C 25 Non-repetitive Peak Forward Surge Current, Rated Load 300 Maximum Forward Voltage Per Bridge Element Specified Current at 12.5 A 1.2 V Maximum Reverse Current at Rated DC Blocking Voltage Per Element 10 µA I2t Rating for Fusing (t
CM25010 价格&库存
很抱歉,暂时无法提供与“CM25010”相匹配的价格&库存,您可以联系我们找货
