DP203A/2123LSL.GN
DP203A/2123LSL.GN
    MULTICOMP
    插件
DP203A/2123LSL.GN 数据手册
Slimline Axial Flow Fans 80mm 92mm 119mm 80mm, 119mm Features: • Low cost, low noise, high pressure fans. • Sleeve bearings. • Rated plastic impellers. • Supplied with 300mm, 22AWG lead wire. 80mm, 92mm, 119mm ‘Slimline’ Features: • Low cost slimline AC fans. • Ball bearing. • Aluminium frame with Rated plastic impeller. • Supplied with a 330mm 24AWG lead wire. Specifications: Motor : Reliable Shaded-Pole Motor Construction. Frame : Die-Cast aluminum housing painted black for moisture and corrosion resistance. Impeller : Injection moulded non-flammable black thermoplastic. Bearing : Precision, life-lubricated ball bearing system. Insulation : Class B integral ground system rated at 120°C. Insulation resistance : 500MΩ minimum at 500V dc. Dielectric strength : 1500V ac for one minute. Precision, oil-impregnated sintered sleeve bearing system. Safety protection : Impedence protected. Operating temperature : -10°C to +70°C. Storage temperature : -40°C to +80°C. Operating voltage : For 115V, ranged voltage from 85V to 125V. Life expectancy : >30,000 hours at 55°C. For 230V, ranged voltage from 185V to 245V. Page 1 30/05/05 V1.0 Slimline Axial Flow Fans 80mm 92mm 119mm Product Guide: Dimensions: 80 x 80 x 25mm • 17 to 22 CFM • 115V or 230V ac, 50/60Hz • Reliable AC motor construction • Impedance protection • Precision Ball Bearing System • 24AWG lead wire Dimensions: 80 x 80 x 38mm Performance HSL Performance HSL • 23 to 31 CFM • 115V or 230V ac, 50/60Hz • Reliable AC motor construction • Impedance protection • Lubricated Sintered Sleeve Bearing System • 22AWG leadwire Dimensions: 92 x 92 x 25mm Performance HST/HSL • 29 to 37 CFM • 115V or 230V ac, 50/60Hz • Reliable AC motor construction • Precision Ball Bearing System • Available with terminal type or leadwire type • 24AWG leadwire Page 2 30/05/05 V1.0 Slimline Axial Flow Fans 80mm 92mm 119mm Plastic Guard is designed to ensure safe operation. Thermoplastic PBT Rating material. PB - 08 for 80mm fan PB - 09 for 92mm fan 80mm, 119mm Height 80 Width 119 Depth 38 Type 80mm, Standard 119mm, Low Noise Bearing Type* SB Frequency (Hz) 50/60 119mm, Standard 119mm, Standard Current (A) 0.15/0.13 0.13/0.11 0.08/0.06 0.21/0.18 0.125/0.11 Power (Watts) 14/12 11/11 11 20/18 18 Speed (RPM) 2300/2750 2000/2200 cu ft/min 23/30 70/76 85/105 107 ltrs/sec 14.1 35.8 49.5 50.4 Static Pressure (Inch-H2O) 0.12/0.18 0.08/0.12 Noise dBA at 1m 31/35 36/38 Air Flow Voltage (V ac) Part Number 115 2550/2900 0.25/0.30 230 43/48 50 115 230 SF11580A/MC1083HSL SP103A/MC1123LSL DP203A/MC2123LSL SP101A/MC1123HSL DP201A/MC2123HSL *SB = Sleeve Bearing Dimensions : Millimetres (Unless Specified) Page 3 30/05/05 V1.0 Slimline Axial Flow Fans 80mm 92mm 119mm 80mm, 92mm, 119mm ‘Slimline’ Height Width 80 92 119 Depth Type 25 80 92 119 Bearing Type* BB Frequency (Hz) 50/60 Current (A) 0.07/0.07 0.12/0.11 0.07/0.06 Power (Watts) 14/13.5 13/12 14.5/14 Speed (RPM) 2450/2900 2350/2850 2150/2300 cu ft/min 18/22 30/37 66/78 ltrs/sec 10.3 17.4 36.7 Air Flow Static Pressure (Inch-H2O) 0.19/0.18 0.09/0.09 19/18 0.13/0.19 0.14/0.16 Noise dBA at 1m 34 37/40 44/46 Voltage (V ac) 230 115 230 115 230 Part Number SF23080AT/ MC2082HBL SF11592A/ MC1092HBL SF23092A/ MC2092HBL SP101AT/ MC1122HBL DP201AT/ MC2122HBL *BB = Ball Bearing Dimensions : Millimetres (Unless Specified) Page 4 30/05/05 V1.0 Slimline Axial Flow Fans 80mm 92mm 119mm Notes: International Sales Offices: AUSTRALIA – Farnell InOne FINLAND – Farnell InOne NETHERLANDS – Farnell InOne SWITZERLAND – Farnell InOne Tel No: Tel No: Tel No: ++ 61 2 9645 8888 Fax No: ++ 61 2 9644 7898 Fax No: ++ 358 9 345 5411 Fax No: ++ 31 30 241 7333 Tel No: ++ 41 1 204 64 64 Fax No: ++ 41 1 204 64 54 AUSTRIA – Farnell InOne FRANCE – Farnell InOne NEW ZEALAND – Farnell InOne UK – Farnell InOne Tel No: Tel No: Tel No: Tel No: ++ 43 662 2180 680 ++ 358 9 560 7780 ++ 33 474 68 99 99 ++ 31 30 241 7373 ++ 64 9 357 0646 ++ 44 8701 200 200 Fax No: ++ 43 662 2180 670 Fax No: ++ 33 474 68 99 90 Fax No: ++ 64 9 357 0656 Fax No: ++ 44 8701 200 201 BELGIUM – Farnell InOne GERMANY – Farnell InOne NORWAY – Farnell InOne UK – BuckHickman InOne Tel No: Tel No: Tel No: ++ 45 44 53 66 66 ++ 44 8450 510 150 ++ 32 3 475 2810 ++ 49 89 61 39 39 39 Fax No: ++ 32 3 227 3648 Fax No: ++ 49 89 613 59 01 Fax No: ++ 45 44 53 66 02 ++ 44 8450 510 130 BRAZIL – Farnell-Newark InOne HONG KONG – Farnell-Newark InOne Tel No: ++ 852 2268 9888 PORTUGAL – Farnell InOne UK – CPC ++ 55 11 4066 9400 Tel No: ++ 34 93 475 8804 ++ 44 8701 202 530 Fax No: ++ 55 11 4066 9410 Fax No: ++ 852 2268 9899 Fax No: ++ 34 93 474 5288 ++ 44 8701 202 531 CHINA – Farnell-Newark InOne IRELAND – Farnell InOne SINGAPORE – Tel No: Tel No: Tel No: ++86 10 6238 5152 Fax No: ++86 10 6238 5022 Farnell-Newark InOne Tel No: ++ 65 6788 0200 ++ 353 1 830 9277 Fax No: ++ 353 1 830 9016 Fax No: ++ 65 6788 0300 export EXPORT – Farnell InOne Tel No: ++ 44 8701 200 208 Fax No: ++ 44 8701 200 209 For enquiries from all other markets DENMARK – Farnell InOne ITALY – Farnell InOne SPAIN – Farnell InOne Tel No: Tel No: Tel No: ++ 45 44 53 66 44 ++ 39 02 93 995 200 ++ 34 93 475 8805 Fax No: ++ 45 44 53 66 06 Fax No: ++ 39 02 93 995 300 Fax No: ++ 34 93 474 5107 ESTONIA – Farnell InOne MALAYSIA – SWEDEN – Farnell InOne http://www.farnellinone.com Tel No: ++ 358 9 560 7780 Fax No: ++ 358 9 345 5411 Farnell-Newark InOne Tel No: ++ 60 3 7873 8000 Fax No: ++ 60 3 7873 7000 Tel No: ++ 46 8 730 50 00 Fax No: ++ 46 8 83 52 62 http://www.buckhickmaninone.com http://www.cpc.co.uk Disclaimer This data sheet and its contents (the "Information") belong to the Premier Farnell Group (the "Group") or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group's liability for death or personal injury resulting from its negligence. Multicomp is the registered trademark of the Group. © Premier Farnell plc 2004. Page 5 30/05/05 V1.0
DP203A/2123LSL.GN 价格&库存
很抱歉,暂时无法提供与“DP203A/2123LSL.GN”相匹配的价格&库存,您可以联系我们找货
