GBPC2510
GBPC2510
    MULTICOMP
    Module
GBPC2510 数据手册
Bridge Rectifier GBPC Series Features: • Plastic material • Integrally moulded heatsink provide very low thermal resistance for maximum heat dissipation • Surge overload ratings from 300 to 400 A • Terminals solderable per MIL-STD-202, method 208 (for wire type) • Typical IR less than 0.2 µA • High temperature soldering guaranteed : 260°C / 10 seconds 0.375 inches (9.5 mm) lead lengths (for wire type) • Isolated voltage from case to lead over 2,500 V GBPC Dimensions : Millimetres Maximum Ratings and Electrical Characteristics Rating at 25°C ambient temperature unless otherwise specified Single phase, half wave, 60Hz, resistive or inductive load For capacitive load, derate current by 20% Type Number Symbol -005 -01 -02 -04 -06 -08 -10 Maximum Recurrent Peak Reverse Voltage VRRM 50 100 200 400 600 800 1,000 Maximum RMS Voltage VRMS 35 70 140 280 420 560 700 VDC 50 100 200 400 600 800 1,000 Maximum DC Blocking Voltage Maximum Average Forward Rectified Current at Tc = 55°C GBPC15 GBPC25 GBPC35 Peak Forward Surge Current, Single Sine-wave Superimposed on Rated Load (JEDEC method) GBPC15 GBPC25 GBPC35 Maximum Instantaneous Forward Voltage Drop Per Element at Specified Current GBPC15 7.5 A GBPC25 12.5 A GBPC35 17.5 A Maximum DC Reverse Current at Rated DC Blocking Voltage per Element Typical Thermal Resistance (Note 1) Operating and Storage Temperature Range I (AV) 15 25 35 Units V A IFSM 300 300 400 VF 1.1 V IR 5 mA RθJC 1.5 °C / W TJ ,TSTG -50 to +150 °C www.element14.com www.farnell.com www.newark.com Page 26/05/12 V1.1 Bridge Rectifier GBPC Series Notes: 1⋅⋅ Thermal Resistance from Junction to Case 2⋅⋅ Suffix “W” - Wire Lead Structure Ratings and Characteristic Curves (GBPC15005 thru GBPC1510, GBPC2510, GBPC35005 thru GBPC3510) Maximum Non-Repetitive Forward Surge Current Per Bridge Element Average Forward Current (A) Peak Forward Surge Current (A) Maximum Forward Current Derating Curve Number Cycles at 60 Hz Case Temperature (°C) Typical Forward Characteristics Per Bridge Element Instantaneous Forward Current (A) Instantaneous Reverse Current (A) Typical Reverse Characteristics Per Bridge Element Percent of Rated Peak Reverse Voltage (%) Forward Voltage (V) www.element14.com www.farnell.com www.newark.com Page 26/05/12 V1.1 Bridge Rectifier GBPC Series Part Number Table Description Part Number Bridge Rectifier, 15 A, 50 V GBPC15005 Bridge Rectifier, 15 A, 100 V GBPC1501 Bridge Rectifier,15 A, 200 V GBPC1502 Bridge Rectifier,15 A, 400 V GBPC1504 Bridge Rectifier,15 A, 600 V GBPC1506 Bridge Rectifier, 15 A, 800 V GBPC1508 Bridge Rectifier, 15 A, 1,000 V GBPC1510 Bridge Rectifier, 25 A, 1,000 V GBPC2510 Bridge Rectifier, 35 A, 50 V GBPC35005B0 Bridge Rectifier, 35 A, 100 V GBPC3501 Bridge Rectifier, 35 A, 400 V GBPC3504 Bridge Rectifier, 35 A, 600 V GBPC3506 Bridge Rectifier, 35 A, 800 V GBPC3508 Bridge Rectifier, 35 A, 1,000 V GBPC3510 Bridge Rectifier, 50 A, 100 V GBPC5001 Bridge Rectifier, 50 A, 400 V GBPC5004 Important Notice : This data sheet and its contents (the "Information") belong to the members of the Premier Farnell group of companies (the "Group") or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group's liability for death or personal injury resulting from its negligence. Multicomp is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com Page 26/05/12 V1.1
GBPC2510 价格&库存
很抱歉,暂时无法提供与“GBPC2510”相匹配的价格&库存,您可以联系我们找货
