CM1504
CM1504
    MULTICOMP
CM1504 数据手册
Single Phase Bridge Rectifiers CM1500 Series Features: • • Metal case for maximum heat dissipation Surge overload ratings to 400 amperes CM Series Dimensions : Inches (Millimetres) Mechanical Data Case Terminals Mounting Position : Metal : Plated 25 inches faston : Any www.element14.com www.farnell.com www.newark.com Page 19/05/12 V1.1 Single Phase Bridge Rectifiers CM1500 Series Maximum Ratings and Electrical Characteristics Ratings at 25°C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load. For capacitive load, derate current by 20% Parameter CM1500 CM1501 CM1502 CM1504 CM1506 CM1508 Maximum Recurrent Peak Reverse Voltage 50 100 200 400 600 800 Maximum RMS Bridge Input Voltage 35 70 140 280 420 560 Maximum DC Blocking Voltage 50 100 200 400 800 800 Unit V Maximum Average Forward Current at TA = 55°C 15 Non-repetitive Peak Forward Surge Current, Rated Load 300 Maximum Forward Voltage Per Bridge Element Specified Current at 7.5 A 1.2 V Maximum Reverse Current at Rated DC Blocking Voltage Per Element 10 µA I2t Rating for Fusing (t
CM1504 价格&库存
很抱歉,暂时无法提供与“CM1504”相匹配的价格&库存,您可以联系我们找货
