ES3B-13-F
ES3B-13-F
    MULTICOMP
ES3B-13-F 数据手册
Surface Mount Rectifier Features: •  •  •  •  •  Low Cost Low Leakage Low Forward Voltage Drop High Current Capability Easily Cleaned With Alcohol,Isopropanol And Similar Solvents Mechanical Data: •  •  •  •  •  Case : JEDEC DO-214AB, molded plastic Terminals : Solderable per MIL- STD-202, Method 208 Polarity : Colour band denotes cathode Weight : 0.007oz, 0.21g Mounting position : Any Maximum Ratings and Electrical Characteristics: Ratings at 25°C ambient temperature unless otherwise specified. Single phase, half wave, 60Hz, resistive or inductive load. For capacitive load,derate by 20%. Characteristics Symbol ES3B-13-F ES3D-13-F Units Maximum recurrent peak reverse voltage VRRM 100 200 V Maximum RMS voltage VRMS 70 140 V Maximum DC blocking voltage VDC 100 200 V Maximum average forward rectified current at TA=110°C IF(AV) 3 A Peak forward surge current 8.3ms single half-sine-wave superimposed on rated load at TJ=125°C IFSM 100 A Maximum instantaneous forward voltage at 3A VF 0.95 V Maximum reverse current at TA=25°C at rated DC blocking voltage at TA=125°C IR 10 500 µA Typical reverse recovery time (Note 1) trr 35 nS Typical junction capacitance (Note 2) cj 45 pF RθJA 25 °C/W TJ, TSTG -55 to +150 °C Typical thermal resistance (Note 3) Operating / Storage junction temperature range Note: (1) Measured with IF=0.5A, IR=1A, Irr=0.25A. (2) Measured at 1MHz and applied reverse voltage of 4V DC. (3) Thermal resistance from junction to ambient and junction to lead PCB mounted on 0.27ʺ × 0.27ʺ ’(7 × 7mm2) copper pad areas. Newark.com/multicomp-pro Farnell.com/multicomp-pro Element14.com/multicomp-pro Page 11/09/19 V1.0 Surface Mount Rectifier Newark.com/multicomp-pro Farnell.com/multicomp-pro Element14.com/multicomp-pro Page 11/09/19 V1.0 Surface Mount Rectifier Dimensions: DO-214AB(SMC) Part Number Table Description Dimensions : Millimetres Surface Mount Rectifier Part Number ES3B-13-F ES3D-13-F Important Notice : This data sheet and its contents (the “Information”) belong to the members of the AVNET group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Multicomp Pro is the registered trademark of Premier Farnell Limited 2019. Newark.com/multicomp-pro Farnell.com/multicomp-pro Element14.com/multicomp-pro Page 11/09/19 V1.0
ES3B-13-F 价格&库存
很抱歉,暂时无法提供与“ES3B-13-F”相匹配的价格&库存,您可以联系我们找货
