1N5402G
1N5402G
    MULTICOMP
1N5402G 数据手册
Standard Diode Features: •  •  •  •  •  •  Glass passivated chip junction High efficiency, Low VF High current capability High reliability High surge current capability Low power loss Specifications: Mechanical Data: Cases : Moulded plastic Lead : Pure tin plated, lead free, solderable per MIL-STD-202, Method 208 guaranteed Polarity : Colour band denotes cathode High temperature soldering guaranteed : 260°C/10 seconds/0.375ʺ, (9.5mm) lead lengths at 5lbs., (2.3kg) tension Weight : 1.2g Maximum Ratings and Electrical Characteristics: Rating at 25°C ambient temperature unless otherwise specified. Single phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. Type Number Symbol 1N5402G 1N5406G 1N5408G Maximum Recurrent Peak Reverse Voltage VRRM 200 600 1,000 Maximum RMS Voltage VRMS 140 420 700 Maximum DC Blocking Voltage VDC 200 600 1,000 Maximum Average Forward Rectified Current 0.375 inch (9.5mm) Lead Length at TA = 60°C I(AV) 3 Peak Forward Surge Current, 8.3ms Single Half Sine-wave Superimposed on Rated Load (JEDEC method) IFSM 125 VF 1 Maximum Instantaneous Forward Voltage at 3.0A Units V A V www.element14.com www.farnell.com www.newark.com Page 28/01/13 V1.0 Standard Diode Type Number Maximum DC Reverse Current at TA = 25°C at Rated DC Blocking Voltage at TA = 125°C Typical Junction Capacitance ( Note 1 ) Typical Thermal Resistance ( Note 2 ) Operating and Storage Temperature Range Symbol 1N5402G 1N5406G 1N5408G Units IR 5 100 Cj 25 pF RθJA 45 °C/W TJ, TSTG -65 to +150 °C μA μA Notes 1: Measured at 1MHz and Applied Reverse Voltage of 4V DC. Notes 2: Mount on Cu-Pad Size 16mm × 16mm on PCB. Ratings and Characteristic Curves (1N5402G, 1N5406G and 1N5408G) www.element14.com www.farnell.com www.newark.com Page 28/01/13 V1.0 Standard Diode DO-201AD Part Number Table Description Part Number Diode, Standard, 3A, 200V 1N5402G Diode, Standard, 3A, 600V 1N5406G Diode, Standard, 3A, 1,000V 1N5408G Dimensions : Inches (Millimetres) Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Multicomp is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com Page 28/01/13 V1.0
1N5402G 价格&库存
很抱歉,暂时无法提供与“1N5402G”相匹配的价格&库存,您可以联系我们找货
