CMS-DF-1025
CMS-DF-1025
    MULTICOMP
CMS-DF-1025 数据手册
Terminal Feature: • Male disconnect, nylon fully insulated with insulation grip. Dimension Table Wire Range (AWG) L W D Male Tab Width (W’) × Thickness Barrel Length Barrel ID Maximum Insulation Diameter Part Number 12 - 10 1.05 0.47 0.39 0.25 × 0.032 0.25 0.15 0.25 CMS-DF-1025 Dimensions : Inches Specifications: Barrel Seam Maximum voltage rating Maximum temperature rating Maximum current Insulator material Terminal material Insulation grip material Plating : Butted with insulation grip. : 600 V building wire 1,000 V signs or fixtures (Luminaries). : 221°F (105°C). : Same as wire. : Nylon. : ETP copper. : Brass. : Tin. Installation Information: Warning Turn power before installing or removing terminal. All electrical work should be done according to appropriate electrical codes. Strip away the end 3/8 inch of wire insulation. Barrel Crimp (Electrical) Insulation Crimp (Mechanical) http://www.farnell.com http://www.newark.com http://www.cpc.co.uk Page 18/07/11 V1.1 Terminal Engineering Specification: Crimp-type male quick disconnect shall, electrically and mechanically connect permanently to a prestripped end of a stranded copper wire and, have a flat rectangular tongue portion for mating to a female quick disconnect in a separable, reusable manner, forming a quick connect wiring connection. The connector line shall offer tongue variations (size 0.25 × 0.032 ANSI / NEMA DC-2) and barrel variations in wire size 12-10 AWG and construction of non-insulated, vinyl insulated, nylon fully insulated, etc. The nylon fully insulated male quick disconnect with insulation grip shall be tin plated 0.032” thick copper, with a 0.25” blade conforming to ANSI / NEMA DC-2 dimensions and a 0.25” long barrel with a tin plated brass insulation grip covered by a moulded nylon funnel entry sleeve which extends to cover the tongue, colour coded, and sized for a specified (AWG) wire range (12-10). Important Notice: Before using this product, you must evaluate it and determine if it is suitable for your intended application. You assume all risks and liability associated with such use. Disclaimer This data sheet and its contents (the "Information") belong to the Premier Farnell Group (the "Group") or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group's liability for death or personal injury resulting from its negligence. SPC Multicomp is the registered trademark of the Group. © Premier Farnell plc 2011. http://www.farnell.com http://www.newark.com http://www.cpc.co.uk Page 18/07/11 V1.1
CMS-DF-1025 价格&库存
很抱歉,暂时无法提供与“CMS-DF-1025”相匹配的价格&库存,您可以联系我们找货
