GBPC5010
GBPC5010
    MULTICOMP
    Module
GBPC5010 数据手册
Bridge Rectifier Features: •  Glass passivated junction •  Plastic material •  Integrally moulded heatsink provide very low thermal resistance for maximum heat dissipation •  Universal 4-way terminals; snap-on, wrap-around, solder or PC board mounting •  Surge overload ratings 400A •  Terminals solderable per MIL-STD-202, Method 208 •  Typical IR less than 0.2μA •  High temperature soldering guaranteed: 260°C/10 seconds/0.375 inch, (9.5mm) lead lengths •  Isolated voltage from case to lead over 2,500V Maximum Ratings and Electrical Characteristics Rating at 25°C ambient temperature unless otherwise specified. Single phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. Type Number Symbol -01 -04 -08 -10 Maximum Recurrent Peak Reverse Voltage Vrrm 100 400 800 1,000 Maximum RMS Voltage Vrms 70 280 560 700 Maximum DC Blocking Voltage Vdc 100 400 800 1,000 Unit V Maximum Average Forward Rectified Current at Tc = 55°C GBPC40 GBPC50 I (av) Peak Forward Surge Current, Single Sine-wave Superimposed on Rated Load (JEDEC method ) GBPC40 GBPC50 Ifsm 400 400 Maximum Instantaneous Forward Voltage Drop Per Element at Specified Current GBPC40 at 20A GBPC50 at 25A Vf 1.1 V Ir 10 mW Rθjc 1.5 °C/W Tj, Tstg -50 to +150 °C Maximum DC Reverse Current at Rated DC Blocking Voltage Per Element Typical Thermal Resistance (Note 1) Operating and Storage Temperature Range 40 50 A Notes: 1. Thermal Resistance from Junction to Case. www.element14.com www.farnell.com www.newark.com Page 05/11/12 V1.0 Bridge Rectifier Ratings and Characteristic Curves (GBPC5001, GBPC5004, GBPC5008, GBPC5010) www.element14.com www.farnell.com www.newark.com Page 05/11/12 V1.0 Bridge Rectifier GBPC40 GBPC40-M Dimensions : Inches (Millimetres) Part Number Table Description Part Number Bridge Rectifier, 50A, 100V GBPC5001 Bridge Rectifier, 50A, 400V GBPC5004 Bridge Rectifier, 50A, 800V GBPC5008 Bridge Rectifier, 50A, 1,000V GBPC5010 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Multicomp is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com Page 05/11/12 V1.0
GBPC5010 价格&库存
很抱歉,暂时无法提供与“GBPC5010”相匹配的价格&库存,您可以联系我们找货
