HK4672X72
HK4672X72
    MULTICOMP
HK4672X72 数据手册
Hour Counter Description: Hour meters HK-46 are designed for the determination and monitoring of operating time, warranty period and maintenance intervals on electrically driven machines and devices, mainly in mechanical processing, woodworking, textile and paper industry, on central heating boilers, electrical furnaces, power drives and rectifiers etc. They are available in a variety of mounting techniques, for all common voltages and with a mounting depth of only 32mm. As a special version, they offer a fully sealed plastic housing. Hour meters are connected in parallel to the control circuit behind the start gear, thus working only during the operation of a machine or device. The hour meters cover a time range from 0 to 99,999.99 h (AC) resp. 999,999.9 (DC). They restart automatically at 0 when leaving the range limit. There is no separate reset facility. Technical Data AC DC Connection: Combined Flat Pins 6.3 × 0.8mm with Screw Terminals Flat Pins 6.3 × 0.8mm Flat Pins 6.3 × 0.8mm with Screw Terminals Flat Pins 6.3 × 0.8mm 25V, 48V, 60V, 110V, 230V, (± 10%) 6 – 30V, 10 – 80V, 110V (± 10%) -Simple Supply Voltage Mains Frequency 50Hz, 60Hz - Motor Synchronous Motor Step Motor Protection Class IP 40 front side IP 40 front side Operating Temp. Range -25°C to +80°C -20°C to +70°C Reading Accuracy 1/100 hour (36 sec.) 1/10 hour (6min.) Counting Range 99,999.99 hours 99,999.99 hours Number of Digits 5 Integers, 2 Decimals 6 Integers, 1 Decimal Digit Size 4mm 4mm Digit Colour Integers: White Decimals: Red Integers: White Decimals: Red Housing Colour Black Black Mounting Fork Clamp G, Snap Fastener F, DIN Rail D, Aluminium Clamp A Fork Clamp G, Snap Fastener F, DIN Rail D, Aluminium Clamp A Front Dimensions 48 × 48mm, 72 × 72mm 55 × 55mm, 72 × 72mm Special Version IP 65 IP 65 www.element14.com www.farnell.com www.newark.com Page 16/10/12 V1.0 Hour Counter Mounting Hole Mounting A x (mm) y (mm) Mounting Hole 48 × 48 6 1 55 × 55 7 1, 2 or 3 72 × 72 7 1, 2 or 3 Mounting D Mounting F x (mm) y (mm) Mounting Hole 48 × 48 6 1 Dimensions : Millimetres www.element14.com www.farnell.com www.newark.com Page 16/10/12 V1.0 Hour Counter Mounting G x (mm) y (mm) Mounting Hole 48 × 48 6 1 55 × 55 7 1, 2 or 3 72 × 72 7 1, 2 or 3 Dimensions : Millimetres Part Number Table Description Part Number HK4624VAC Hour Counter, Elect-Mech HK46110VAC HK46240VAC Bezel, 55 × 55 HK4655X55 Bezel, 72 × 72 HK4672X72 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Multicomp is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com Page 16/10/12 V1.0
HK4672X72 价格&库存
很抱歉,暂时无法提供与“HK4672X72”相匹配的价格&库存,您可以联系我们找货
