507-1290
507-1290
    MULTICOMP
507-1290 数据手册
Type HS10 Solder Wire Description The electronic solder wire HS10 is a proven and reliable product of research, which was developed to meet high quality requirements in industrial electronic production as well as for quick rework. The solder wire HS10 is very efficient by its high activity, which results in quick spread of solder and electrical safe residues. It is a halide activated rosin (colophony) flux. The solder wire HS10 according to J-STD-004 type ROM1. Applications The solder wire HS10 can be used for hand and robot soldering in electronics and electrical assembly, audio devices and telecommunication. Flux residues can remain on surfaces without cleaning. Features •  Solid and dry residues, pin testable •  Fast soldering, high spread speed •  High reliability Physical Properties and Data General Properties HS10 Flux Type ROM1 / J-STD-004 Flux Content standard 2.5 weight % ± 0.3 % Halide Content 0.9% Corrosion Effect None / J-STD-004 Standard alloys acc. to ISO 9453:2014 Lead-containing: Lead-free (Ecoloy Serie) S-Sn60Pb40 Ecoloy TS (S-Sn96.3Ag3.7) S-Sn60Pb39Cu1 Ecoloy TSC (S-Sn95.5Ag3.8Cu0.7) S-Pb60Sn40 Ecoloy TC (S-Sn99.3Cu0.7) S-Sn62Pb36Ag2 Ecoloy TSC305 (S-Sn96Ag3Cu0.5) S-Sn63Pb37* - S-Pb93Sn5Ag2 - Available Diameters from 0.3mm Available Reel Sizes 250g * This alloy is subject to a MOQ Newark.com/exclusive-brands Farnell.com/exclusive-brands Element14.com/exclusive-brands Page 25/08/21 V1.0 Type HS10 Solder Wire Part Number Table Description Part Number Solder Wire, Lead Free, 0.5mm, 250g 595000 Solder Wire, Lead Free, 0.5mm, 250g 507-1290 Solder Wire, Lead Free, 0.7mm, 250g 595001 Solder Wire, Lead Free, 0.7mm, 250g 595021 Solder Wire, Lead Free, 0.7mm, 500g 595024 Solder Wire, Lead Free, 0.9mm, 250g 507-1318 Solder Wire, Lead Free, 0.9mm, 500g 507-1355 Solder Wire, Lead Free, 1.2mm, 250g 595003 Solder Wire, Lead Free, 1.2mm, 250g 507-1320 Solder Wire, Lead Free, 1.2mm, 500g 507-1367 Solder Wire, Lead Free, 1mm, 250g 595002 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the AVNET group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Multicomp is the registered trademark of Premier Farnell Limited 2019. Newark.com/exclusive-brands Farnell.com/exclusive-brands Element14.com/exclusive-brands Page 25/08/21 V1.0
507-1290 价格&库存
很抱歉,暂时无法提供与“507-1290”相匹配的价格&库存,您可以联系我们找货
