8588-0207A
8588-0207A
    MULTICOMP
8588-0207A 数据手册
Coupler 6P4C (Cross) Specifications 468 Housing    Material   Colour : ABS, UL 94V-2. NO Poison : Ivory Electronic Wire Set   UL 1061 Electronic Wire    Conductor    Insulation : Bare copper wire 00.48mm (AWG 26) : SR-PVC, 0 0.97 ±0.1mm   O Type Terminal    Material : Bronze   Wire Terminal   Material : Bronze   Gold Wire     Contact : Phosphor Bronze, 15μ" Gold over Nickel under plated   1.9 × 6 Screw   Material     Plating : Iron : Nickel Diagram Dimensions : Millimetres Note: Double-sided adhesive foam cotton 50mm × 50mm, t = 2mm Material Name Weight Unit % Top Cover 9.9 g 29.08% Base Cover 13 g 38.19% Twin Adhesive 0.9 g 2.64% Ziplock 0.9 g 2.64% Plastic Inner 0.64 g 1.88% Screw 5.4 g 15.86% www.element14.com www.farnell.com www.newark.com Page 16/10/17 V1.1 Coupler 6P4C (Cross) Material Name Weight Unit % Screw 1.4 g 4.11% Round Terminal 0.8 g 2.35% Electronic Wire 0.6 g 1.76% Terminal 0.402 g 1.18% Gold Wire 0.102 g 0.3% Total 34.044 g 100% Part Number Table Description Part Number Connector, Modular, Jack, 6P6C, 1 Port 8588-0207A Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. Multicomp is the registered trademark of the Group. © Premier Farnell Limited 2016. www.element14.com www.farnell.com www.newark.com Page 16/10/17 V1.1
8588-0207A 价格&库存
很抱歉,暂时无法提供与“8588-0207A”相匹配的价格&库存,您可以联系我们找货
