DSI-DSIEC-EV-32P-3C
DSI-DSIEC-EV-32P-3C
    MULTICOMP
DSI-DSIEC-EV-32P-3C 数据手册
REVISIONS PART NO. DSI-DSIEC-EV-32P-3C ECN # REV DESCRIPTION DRAWN DATE CHECKD DATE APPRVD DATE - 1.0 RELEASED AB 18/04/12 ER 18/04/12 ER 18/04/12 Features •  32 AMP Cable 3G6.0 + 2 × 0.5mm ≤ Orange •  Custom Options on Cable Length and Colour Specification Current and Voltage Signal Current Protection Degree Charging Cable Charging Cable : 32A 240V AC : 2A < 30V DV : IP44 : 32A 1P + N + PE + PP + CP : 3,000mm / 5,000mm 3 x 6mm² + 2 - 0.5mm² The plug was designed according to the standard of SAE J1772-2010 The static resistance is 150 ohm, and the resistance will increase to 480 ohm when pressing the button The plug II, was designed according to the standard of 62196-2 IEC 2010 sheet 2-IIb The static resistance is 220 ohm Cable Specification Function 32A 240V L1 (1) 6mm2 N (2) 6mm2 PE (3) 6mm2 CP (4) 0.5mm2 PP (5) - www.element14.com www.farnell.com www.newark.com Dimensions : Millimetres (Inches) Important Notice :  This data sheet and its contents (the “Information”) belong to the members of the ­Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any ­intellectual property rights is granted. The Information is ­subject to change without notice and replaces all data sheets ­previously supplied. The ­Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not o ­ perate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. ­Multicomp is the registered trademark of the Group. © Premier Farnell plc 2012. TOLERANCES: DRAWN BY: AB UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE FOR REFERENCE PURPOSES ONLY. CHECKED BY: ER APPROVED BY: ER DATE: 18/04/12 DATE: 18/04/12 DATE: 18/04/12 DRAWING TITLE: Plug 3M Cable SIZE DWG NO. ELECTRONIC FILE A4 DSI-DSIEC-EV-32P-3C-01 SCALE: NTS REV DSI-DSIEC-EV-32P-3C-1 U.O.M.: mm (inch) SHEET: 1 of 2 1.0 REVISIONS PART NO. DSI-DSIEC-EV-32P-3C ECN # REV DESCRIPTION DRAWN DATE CHECKD DATE APPRVD DATE - 1.0 RELEASED AB 18/04/12 ER 18/04/12 ER 18/04/12 Part Number Table Description Part Number Cable, J1772 Plug - 62196-2 Plug, 3M DSI-DSIEC-EV-32P-3C www.element14.com www.farnell.com www.newark.com Important Notice :  This data sheet and its contents (the “Information”) belong to the members of the ­Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any ­intellectual property rights is granted. The Information is ­subject to change without notice and replaces all data sheets ­previously supplied. The ­Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not o ­ perate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. ­Multicomp is the registered trademark of the Group. © Premier Farnell plc 2012. TOLERANCES: DRAWN BY: AB UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE FOR REFERENCE PURPOSES ONLY. CHECKED BY: ER APPROVED BY: ER DATE: 18/04/12 DATE: 18/04/12 DATE: 18/04/12 DRAWING TITLE: Plug 3M Cable SIZE DWG NO. ELECTRONIC FILE A4 DSI-DSIEC-EV-32P-3C-01 SCALE: NTS REV DSI-DSIEC-EV-32P-3C-1 U.O.M.: mm (inch) SHEET: 2 of 2 1.0
DSI-DSIEC-EV-32P-3C 价格&库存
很抱歉,暂时无法提供与“DSI-DSIEC-EV-32P-3C”相匹配的价格&库存,您可以联系我们找货
