Diode
Ultra Fast
Features:
Glass passivated junction chip
For surface mounted application
Low profile package
Built-in strain relief
Ideal for automated placement
Easy pick and place
Super fast recovery time for high efficiency
Glass passivated chip junction
High temperature soldering: 260°C/10 seconds at terminals
Plastic material
Specifications:
Mechanical Data:
Cases
: Moulded plastic
Terminals
: Pure tin plated, lead free
Polarity
: Indicated by cathode band
Packing
: 16mm tape per EIA STD RS-481
Weight
: 0.21g
Maximum Ratings and Electrical Characteristics
Rating at 25°C ambient temperature unless otherwise specified.
Single phase, half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
Type Number
Symbol
ES3A
ES3F
ES3H
ES3J
Maximum Recurrent Peak Reverse Voltage
Vrrm
50
300
500
600
Maximum RMS Voltage
Vrms
35
210
350
420
Maximum DC Blocking Voltage
Vdc
50
300
500
600
Maximum Average Forward Rectified Current
I(av)
3
Peak Forward Surge Current, 8.3ms A
Single Half Sine-wave Superimposed on Rated
Load (JEDEC method) at TL = 100°C
Ifsm
100
Units
V
A
www.element14.com
www.farnell.com
www.newark.com
Page
08/02/13
V1.0
Diode
Ultra Fast
Type Number
Symbol
ES3A
Maximum Instantaneous Forward Voltage
at 3.0A
Vf
0.95
Maximum DC Reverse Current at TA = 25°C
at Rated DC Blocking Voltage at TA = 100°C
Ir
10
500
μA
μA
Maximum Reverse Recovery Time (Note 1)
Trr
35
nS
Typical Junction Capacitance ( Note 2 )
Cj
Maximum Thermal Resistance (Note 3)
ES3F
1.3
45
30
RθJA
Tj
Storage Temperature Range
Tt
ES3J
Units
1.7
V
pF
47
12
°C/W
-55 to +150
°C
RθJL
Operating Temperature Range
ES3H
Notes: 1. Reverse Recovery Test Conditions: If = 0.5A, Ir = 1.0A, Irr = 0.25A.
Notes: 2. Measured at 1MHz and Applied Vr = 4V.
Notes: 3. Units Mounted on PCB with 0.6ʺ × 0.6ʺ (16mm × 16mm) Copper Pad Areas.
Ratings and Characteristic Curves (ES3A, ES3F, ES3H and ES3J)
www.element14.com
www.farnell.com
www.newark.com
Page
08/02/13
V1.0
Diode
Ultra Fast
www.element14.com
www.farnell.com
www.newark.com
Page
08/02/13
V1.0
Diode
Ultra Fast
Note: 1. Rise Time = 7ns Maximum. Input Impedance = 1 MΩ 22pf
Note: 2. Rise Time = 10ns Maximum Source Impedance = 50Ω
Part Number Table
Dimensions : Inches (Millimetres)
Description
Part Number
Diode, Ultra-Fast, 3A, 50V
ES3A
Diode, Ultra-Fast, 3A, 300V
ES3F
Diode, Ultra-Fast, 3A, 500V
ES3H
Diode, Ultra-Fast, 3A, 600V
ES3J
Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted
for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change
without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any
error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any
assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the
Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence.
Multicomp is the registered trademark of the Group. © Premier Farnell plc 2012.
www.element14.com
www.farnell.com
www.newark.com
Page
08/02/13
V1.0
很抱歉,暂时无法提供与“ES3H”相匹配的价格&库存,您可以联系我们找货
