GBPC2506
GBPC2506
    MULTICOMP
    Module
GBPC2506 数据手册
Glass Passivated Bridge Rectifiers GBPC 25 Series Features: • • • • • • • The plastic material Integrally moulded heatsink provide very low thermal resistance for maximum heat dissipation Surge overload ratings from 300 to 400 A Terminals solderable per MIL-STD-202, method 208 (for wire type) Typical IR less than 0.2 µA High temperature soldering guaranteed, 260°C / 10 seconds 0.375 inches (9.5 mm) lead lengths (for wire type) Isolated voltage from case to lead over 2,500 V GBPC Dimensions : Inches (Millimetres) www.element14.com www.farnell.com www.newark.com www.cpc.co.uk Page 09/06/12 V1.1 Glass Passivated Bridge Rectifiers GBPC 25 Series Maximum Ratings and Electrical Characteristics Rating at 25°C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load. For capacitive load, derate current by 20% Type Number GBPC2501 GBPC2502 GBPC2504 GBPC2506 Maximum Recurrent Peak Reverse Voltage 100 200 400 600 Maximum RMS Voltage 70 140 280 420 Maximum DC Blocking Voltage 100 200 400 600 Maximum Average Forward Rectified Current at TC = 55°C Unit V 25 A Peak Forward Surge Current, Single Sine-wave Superimposed on Rated Load (JEDEC method ) 300 Maximum Instantaneous Forward Voltage Drop Per 12.5 A Element at Specified Current 1.1 V Maximum DC Reverse Current at Rated DC Blocking Voltage Per Element 5 mA Typical Thermal Resistance (Note 1) RθJC 1.5 °C / W -50 to +150 °C Operating and Storage Temperature Range TJ, TSTG Notes: 1. Thermal resistance from junction to case Ratings and Characteristic Curves Fig. 3 Typical Reverse Characteristics Per Bridge Element Average Forward Current (A) Instantaneous Reverse Current (A) Fig. 1 Maximum Forward Current Derating Curve Case Temperature (°C) Percent of Rated Peak Reverse Voltage (%) www.element14.com www.farnell.com www.newark.com www.cpc.co.uk Page 09/06/12 V1.1 Glass Passivated Bridge Rectifiers GBPC 25 Series Fig. 4 Typical Forward Characteristics Per Bridge Element Instantaneous Forward Current (A) Peak Forward Surge Current (A) Fig. 2 Maximum Non-Repetitive Forward Surge Current Per Bridge Element Number Cycles at 60 Hz Part Number Table Description Part Number Bridge Rectifier, 25 A, 100 V GBPC2501 Bridge Rectifier, 25 A, 200 V GBPC2502 Bridge Rectifier, 25 A, 400 V GBPC2504 Bridge Rectifier, 25 A, 600 V GBPC2506 Forward Voltage (V) Important Notice : This data sheet and its contents (the "Information") belong to the members of the Premier Farnell group of companies (the "Group") or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group's liability for death or personal injury resulting from its negligence. Multicomp is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk Page 09/06/12 V1.1
GBPC2506 价格&库存
很抱歉,暂时无法提供与“GBPC2506”相匹配的价格&库存,您可以联系我们找货
