HTC210M
HTC210M
    MULTICOMP
HTC210M 数据手册
REVISIONS PART NO. HTC210M ECN # REV DESCRIPTION DRAWN DATE CHECKD DATE - A RELEASED SID 04/5/12 AMU 04/5/12 APPRVD DATE 18/5/12 Feature: • PC board mounted fuse clip with end stops Specifications: Material : Hard brass 30 SWG Finish : Pure tin plated 4 to 10 µ inches Part Number Table Description Part Number Fuse Clip, 20 × 5 mm, PK200 HTC210M Pins shall be capable of direct insertion into a JIG The base of the clip contacts, the seating plane, without the need to bend the pins to effect entry Gauge Tolerances : ±0.02 Plate Thickness : 3.783 to 4.037 www.element14.com www.farnell.com www.newark.com Dimensions : Millimetres Important Notice : This data sheet and its contents (the "Information") belong to the members of the Premier Farnell group of companies (the "Group") or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group's liability for death or personal injury resulting from its negligence. Multicomp is the registered trademark of the Group. © Premier Farnell plc 2012. TOLERANCES: UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE FOR REFERENCE PURPOSES ONLY. DRAWN BY: SID CHECKED BY: DATE: 04/05/12 DATE: AMU 04/05/12 APPROVED BY: DATE: 18/05/12 DRAWING TITLE: Fuse Clip SIZE A DWG NO. SCALE: NTS M10002160 U.O.M.: mm REV ELECTRONIC FILE A 33188_DWG SHEET: 1 OF 1
HTC210M 价格&库存
很抱歉,暂时无法提供与“HTC210M”相匹配的价格&库存,您可以联系我们找货
HTC210M
    库存:27
